Windows Fundamentals for Legacy PCs
  • Windows Fundamentals for Legacy PCs
    Does anyone have any experience with this? From what I've read, it may have some potential. It is an official OS from Microsoft based on XP embeded. I have never used it, but it supposedly works on older machines with very limited resources.
    okay i read like one paragraph on the windows site and it looks like it is server client type software. Where the old pc turns into a terminal that will connect to a server will all the windows xp stuff. I dont think it is something we will be using here. Unless someone wants to put a slow computer for every seat in the car and have one main super server to manage it all.
    edit: quote from microsoft
    Windows Fundamentals for Legacy PCs is not a general-purpose operating system. It is designed to work with the Microsoft Remote Desktop Connection client or third-party clients, such as Citrix ICA. In addition, it allows for a limited number of workloads to be executed locally, including security software, management software, terminal emulation software, document viewers, and the .NET Framework.
    Maybe it can run local programs too but more or less designed for terminal type aplications.
    Um, I guess this is where you put something witty.WITTY
    My Web site, in the design stage. http://home.comcast.net/~cstrachn
    Modified RRSkinEditor http://www.mp3car.com/vbulletin/showthread.php?t=65723
      WinFLP can be installed as a stand-alone OS. It's basically a stripped down version of XP that can be run with much lower hardware requirements. The minimum requirements are 233 MHz Pentium class processor, 64 MB of RAM, 610 MB of HD space (this is for the windows install, actual disk space used) and 800x 600 video resolution.
      I tried a build with it over the weekend and I was having some issues with my serial to usb devices and it not accepting the drivers. I haven't worked that issue out yet. But it made of a quick and responsive build of windows otherwise.
        Someone else mentioned Windows Funamentals for Legacy PCs (WinFLP) so I asked work to obtain a copy for me. They duly did, and on an IBM T23 Laptop I recently aquired, did two installs; one a clean simple copy of Windows XP Professional SP2, the second a clean install of WinFLP. After the install, and configuring both to boot straight to desktop with no logon, I got the following boot-times:
        WinXP Pro SP2: 34.1seconds to desktop
        WinFLP: 38.5seconds to desktop
        This is on an IDENTICAL machine - IBM T23 Thinkpad 1.13Ghz PIII, 512Mb ram, ATA133 2.5" Hitachi HDD, to a resolution of 1024x768. No additional drivers, updates or tweaks were made.
        I suppose the next test would be to run benchmarking software, but I don't have the energy to reinstall XP Pro again on this machine! However, if someone wants to give me an nlite config I'll pack my own install and try that out as a comparison as well if need be.
        http://sticksout.blogspot.com
          I managed to get the bootup time (load to desktop, no hourglass icon) down to 28.5 seconds using Minlogon. Really simple to set up too, and that's from a cold boot. For a CarPC environment, I'm happy with that. No Hacks, no tweaks, no playing around disabling and enabling services.
            imo the only way you are going to get a faster boot time is to modify xp enough. I'm actually in the process of doing that now. Right now my windows folder is at 250 megs versus the 1.12 gigs you get when xp is installed
              Current Windows folder size after installing WinFLP is 517Mb
                winflp is a great thing I just think you need to tweak xp a little bit more
                  Yeah, Im sure you can tweak XP right down to an amazingly tight fast system. However, for those of us who get overly confused with nlite and aren't comfortable fiddling around with the registry, I'll give WinFLP + minlogon a big thumbs up for small-footpring speedy startups, straight from installation.
                    you should never use nlite (or any other program for that matter) and you don't have to do registery hacks either..simply
                    - removing the services you don't need
                    - removing themes
                    - removing the majority of Accessories
                    empty your trash
                    then run a registry cleaner restart
                      I'm going to resurrect this thread and say that nLite, when used properly, could do more for you than a full install and then removing all that crap ever could.
                      Why install that stuff when you can nLite it away before it even touches your system? I've gotten some very small, VERY fast installs of XP and Server 03 out of nLite. More than I had ever gotten from a full install + removing stuff.
                      You're basically doing the same thing, but before the install instead of after, thereby removing any chance of having residual junk left from installing and then uninstalling.
                      Tidder
                      Try RevFE
                      I Wish I could ban people
