New EWF & HORM manager tool
  • New EWF & HORM manager tool
    Hello,
    I have coded a small utility to simplify the handling of EWF and HORM features and I would like to share it.
    This utility, EWF&HORMmanager, (written with AutoIt v3, http://www.autoitscript.com/autoit3/) can be used to enable/disable EWF and HORM (on the system disk only): it's a GUI for the "ewfmgr" command line program. Moreover it can be used to unmount the disks not EWF-protected and to start the hibernation process.
    In order to use EWF&HORMmanager you should have installed properly EWF & HORM tecnologies from XP Embedded Feature Pack 2007.
    The included program "hibernate4HORM" is derived from source code published by Microsoft (http://msdn.microsoft.com/en-us/library/aa460084.aspx); it's used by EWF&HORMmanager to lock and unmount the EWF-unprotected drives, to hibernate the system and then (at resume time) to unlock the drives.
    I know that there is almost another tool doing the same thing, the HORM Manager Lite from Wechsler Consulting, but I found some problems running that tool with XPe FP 2007 and I would like a simpler GUI...
    Hope this can be useful to someone...
    huge63
    I'll try it out, looks very handy.
      nice...one problem though. I tried running it on my carpc setup and I get the error saying I need xpepm tool. Is this in the xpe packages somewhere?
      Also, I'm running server 2003 if that makes any difference.
        I'm sorry, I forgot to say that EWF&HORMmanager requires xpepm.exe and xpepm.dll from Windows XP Embedded SP2. You should take tham from the binaries catalog of the evaluation version and put them in C:\WINDOWS\System32...
        huge63
          Seems very useful, thanks, I'll try it out..
            EWF & HORM manager tool update
            I forgotted to disable "horm.dat" flag file when disabling HORM, so "normal" restore from hibernation file was not possible. In version 1.1 HORM disable renames the flag file, so that it's possible to use HMRM... :-)
            huge63
              huge63
              Any possibility that these can be posted? gonna be a pain just to download/install to get 2 files.
              2011 Nissan Frontier SL
              AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
              OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
                bump... i can't find the files anywhere in the sp2 eval kit
                  Here are all the ewf - horm files you should need
                  HERE ARE ALL THE EWF - HORM FILES YOU SHOULD NEED
                  I take credit for none of this.
                  I can't provide any support, I barely understand it myself.
                    Thanks for this share
                      I know its a bit old thread. But one question;
                      does it matter if hdd control is IDE or AHCI mode?
                      I want to use both ewf and horm on my win7 x86 OS.
                      Zotac Zbox id80
                      64Gb Sansdisk SSD
                      4Gb Ram, BU-353-S4 Gps
                      7" resistive touch screen
                      Win7 x86, BS 10.0.470, RR, Reborn,
                      KKCanBus, BT Mobilephone, igo8.3, Garmin
                        Seems like both is OK. Tested myself on win7 x86 embedded sp1.
                        Zotac Zbox id80
                        64Gb Sansdisk SSD
                          Hello.
                          Time is going but is there someone out there who owns this file by now? All Links dead, but maybe i need it to test and use.
                          All hints apreciated.
                          Baerchen
