Windows 7 Optimizations
This is a sticky topic.
  • Windows 7 Optimizations
    Starting this off with some simple stuff to have a "clean" start up look and feel:
    bcdedit /set bootux disabled (blank screen instead of animation)
    bcdedit /set quietboot on (no progress bars, even in resume from hibernate)
    bcdedit /set bootstatuspolicy ignoreallfailures (disable recovery console which is useless in the car, you shouldn't be BSOD'ing out anyhow)
    BCDEdit docs here: http://msdn.microsoft.com/en-us/library/aa906211.aspx
    USB Troubleshooting Tips:
    Using Event Tracing to debug USB issues: http://blogs.msdn.com/usbcoreblog/ar...ore-stack.aspx
    Fixing USB devices that don't work after system resume: http://blogs.msdn.com/usbcoreblog/ar...em-resume.aspx
    EWF, HORM, MinLogon on XP.
    Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
    Win Embedded Std 2011 RC
    OCZ Vertex Turbo 30GB SSD
    Lilliput 629 Transflective, WRX Screen Mount
    BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
    VoomPC 2
    antimatter found this good tip in order to reduce you hibernation file size. I'm copying and pasting from his post:
    if you have 2gigs of memory but only consistently use less than 1gig of physical memory type:
    powercfg.exe -h -size 50
    (50 being the percentage of total)
    This will make the hibernate file 1/2 the total physical memory which should speed up resume from hibernate times.
    Note that the minimum size you can set, according to MSDN, is 50%. More info here: http://download.microsoft.com/downlo...Footprint.docx
    VoomPC 2
      thank you guys
      very helpful
      trinybwoy
      2006 Mazda6 Carpc
      2008 Acura TSX Nexus 7
        Awesome. No need to hack any system files like in XP. Will try it out, thanks!
          why not use less ram instead?
            Because the would make sense
            Truthfully, due to memory fragmentation, you would have much better results using just a single gig of RAM
            openMobile - An open source C# Front End (why choose openMobile?)
            - Always Recruiting Developers -
            Like what you see? Donations are always welcome
              since ram is cheap some people may have gotten more than necessary to give them enough wiggle room to expand. in reality, with a slimmed down OS ram usage is much lower. so this at least gives you an option to compensate for the unused ram in the event that removing physical ram isn't an option?
              VoomPC 2
