FIX: CTRL ALT DEL with "MinLogon"
This is a sticky topic.
  • FIX: CTRL ALT DEL with "MinLogon"
    Here is the fix for those using minlogon and would like to have
    Ctrl Alt Del working again.
    Code:
    2004 FrodoPlayer.com
    2004 Kevin Lincecum
    CAD_Trap Service
    Purpose: To detect CTRL ALT DEL and launch the task manager.
    Used for systems using "minlogon" which do not catch this message.
    Installation:
    Put the files where you want them installed.
    Run install.bat
    Reboot
    To remove, first stop the service.
    Then run uninstall.bat
    Reboot, then remove the files.
    Note: If you want the service to restart if killed, you
    must set this manually in the service manager of windows.
    Changing the Path to Task Manager (or use an alternate)
    Edit CAD_Trap.ini
    Put in the appropriate values.
    Enjoy.
    Frodo
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Thanks man!
    EWF, HORM, MinLogon on XP.
    Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
    Win Embedded Std 2011 RC
    OCZ Vertex Turbo 30GB SSD
    Lilliput 629 Transflective, WRX Screen Mount
    BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
    VoomPC 2
      Originally posted by SFiorito
      Thanks man!
      No problem. Make sure and tell me if it works right.
      [H]4 Life
      I'm a lesbian too.
      I am for hire!
        Anyone test yet ?
        [H]4 Life
        I'm a lesbian too.
        I am for hire!
          i will test tonight
          We are, will have and forever will be...
          But not tommorrow!
            Works for me. I just installed it and started the service up
            Wayne
              Works for me to!
              But not tommorrow!
                Woot !
                [H]4 Life
                I'm a lesbian too.
                I am for hire!
                  Nice one. You dont know what youv'e got till its gone...
                    great, thanks
                      Works great, thanks!
                        Works with XP SP3 too!
                        Worklogs: 08 Sequoia Platinum Carputer (In Progress!)
                        Skin: MetroSex on the Beach preview
                        07 Infiniti Fx35 (done!) & 06 Infiniti M35 (gone...)
                          Another option
                          I like this program,
                          I put together my own for the sake of it. I'll post the source per request.
                          Usage: put program in start menu, then press ctrl-alt-del for task manager.
                          Hope this is useful.
                            I have a question about this. I know minlogon screws with Ctrl-Alt-Del, but does it in any way prevent Ctrl-Alt-Esc from functioning? (this is the lesser known shortcut to Task Manager).
                            2000 Ford Expedition Eddie Bauer - Bi-Fuel Gasoline/CNG
                            Intel D945GCLF2 w/512MB RAM, CL Audigy w/KxProject, M2-ATX, Lilliput EBY701
