bootprep.exe
  • bootprep.exe
    i don't have bootprepon my xpe ( modified by my enterprise)
    is a person can send me bootprep.exe ???
    Link:
    http://www.acrosser.com/winEOS/winxp.htm
    And this?
    Mauri
      I'm trying to run this from winxp with my CF as drive E... however I am getting a messagebox error...
      If I click ignore I get this:
      Code:
      C:\>bootprep /dE
      BOOTPREP build 807
      Microsoft (R) Windows XP Embedded,
      Copyright (C) 1981-2001 Microsoft Corp.   All rights reserved.
      C:\>
      Is this it? It doesnt seem to be doing anything in the partition....
      Roy
      2005 Range Rover 4.4
        it needs to be run from DOS...
        http://osf1.gmu.edu/~sfiorito/eXPinstall.htm
        EWF, HORM, MinLogon on XP.
        Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
        Win Embedded Std 2011 RC
        OCZ Vertex Turbo 30GB SSD
        Lilliput 629 Transflective, WRX Screen Mount
        BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
        VoomPC 2
          SFiorito, this one and me forgetting about bootprep all together mean Im going bezerk.... I'll try to read everything a bit more from now on....
          Roy
            Hey Guys...
            OK I seem to have done all the steps... however my carpc still doesnt boot off the CF card.... it says something like "Choose a valid boot device or insert a valid boot media into the selected device"....
            weird thing is, on another computer WinXP starts booting from the CF card (although it crashes midway and reboots - but I guess this is cause the hardware is very different)
            Roy
              can you even boot into DOS using the CF card?
              did you partition, format, and run bootprep on the same system that you're trying to boot from?
              VoomPC 2
                It did boot into MS-DOS, but now isnt doing it anymore.... tomorrow or saturday I will redo the entire process... sorry for these questions and thanks for being so helpful!
                Roy
                  Hey Guys.... It seems that for some reason my new CarPC isnt liking the CF card thing... I am unable to do a FDISK when I load the CF card as primary master and boot from CDRom (msdos boot cd)... it says invalid disk or something of the sort...
                  I am able to fdisk from another computer onto the CF card, however if I do the whole process on another computer I still cant get it to boot off the CF on my CarPC (Asus Pundit mobo)...
                  Bios recognizes the CF card as a "IDE Hard Disk" and then as "Sandisk xxxx" (model number)... has anyone stumbled across these problems?! it seems that the mobo refuses to boot off the CF, or to allow access to it despite seeing it as a "valid hd in bios".
                  I'm pulling out my hairs.... dunno what to do!
                  Roy
                    what SanDisk card are you using and what CF-IDE adapter?
                    VoomPC 2
                      UltraII and logcsupply (tried 2 cards, same model, on both the plugin style adapter as well as the adapter that has a IDE plug).... Already updated bios to latest available beta, absolutely no effect
                      Roy
                        what cable you using? 40 conductor cable or new ATA style 80 conductor cable? i think this might be the same problem I was having when I first started all this. you have to use the older style cables. also, you're formatting the drive as FAT32?
                        VoomPC 2
                          Hey SFiorito,
                          I really hope your patience isnt running out on me.... I'm really sorry for all these problems mate...
                          I will check what cable it is (they are normal IDE cables AFAIK)... however one of the CF-IDE adapters I'm using (the one i'm using for most of the tests) is a direct plugin into the Mobo...
                          I initially formatted and created the partition with MS-DOS 6.22 bootdisk using FAT (not FAT32) on another computer, but when I try to boot or access (fdisk or even "c:" or whatever letter I try) I cant access, or when I try to run FDISK i get "Unable to read physical drive" (something to this effect - im far from the machin ATM_
                          Roy
                            no, my patience isn't running out...
                            your BIOS harddrive settings are all set to AUTO right? i'm trying to think of what else it could be...
                            VoomPC 2
                              Originally posted by RoyN
                              Hey SFiorito,
                              Try to set your C/H/S manually, identical to how the other booting pc detects them, sometimes it helps...
                              List of front-ends/usefull apps
                              XTroniC | XTroniC Direct
