Reduced Hiber Time..... idea
  • Reduced Hiber Time..... idea
    K, onthe hibernation tabit shows how much space is required to hibernate....
    You cant change it from there.
    nowwe all know hibernation times are faster if less RAM is used - so what can we do to reduce the amount of moemmory hybernation uses - is there stuff we can cut out - like only save certain things??
    Can we force a maximum size to save???
    All this would make things faster!!!
    You could possible put your hibernation file on a small disc partition but i don't know what would happen if the space was not big enough - probably cause a crash. I guess you can see the approximate amount by looking at the estimation in windows.
