Hibernation
  • Hibernation
    I know just don't use hibernation is the key answer here. Nut I oh so just love my music just starting up 20 seconds after I get in my car. Anywho it worked great for me for like 3 months then I had power supply issues and thought that was this problem.
    So now I have replaced the power supply and now it still does this. Ok it comes out of hibernation just dandy then works for a good 30-45 seconds and bang video cuts out. I pop down the rear seat and look at the pc its running fine all usb items on, fan is running but no video next going to test with another video card but if anyone has had this issue or has any ideas let me know
    Thanks,
    Dustan
    Toyota Prius w/ NAV system and a 30gb Ipod :)it never crashes and always boots up.
    nevermind seems it does it regardless. Seems to be like randomly 15-45 seconds it just looses it reboots or just dies maybe should just but a new mobo any suggestions? once it boots it never restarts but booting makes it crazy and reboots here and there during startup could it even be the cold its 22 here now and never did it in the summer but i dunno
      Are you using an ITPS? If so, is this problem occurring when the car is off or on?
      Want to:
        Nope is a brand new Opus 150 and its when the car is on
          Check if everything is seated correctly, especially your hard drive.
          PowerVoice v1 | NaviVoice Source
          GammaControl v2.4
          SKINbedder v3
          1995 Lexus SC300
            But it's only after hibernation? I'm not computer expert, but I have heard of problems with USB devices not working after hibernation of other drivers not reloading. I have mine set to not hibernate....I just have it go into standby mode 3 minutes after the Ignition shuts off. Then I have a diode-isolated feed from the dome light, through a relay, that turns the computer on on a dome light event. This restarts the CPU as soon as I open the door, so when I get in and crank the key, the LCD turns on and the computer's already up and running. The computer will stay in standby all day or overnight with an optima deep-cycle battery in the trunk that is isolated from the starting battery, allowing the computer to run on until the optima dies <never happened yet>.
              I know this is an old thread, but I would like to know how you did this as that is the same way I want to set up my car pc. Any help that you can offer would be greatly appreciated. TIA, Doug.
                Im sadly had this problem with my gaming rig in my house and I ended up finding out I had a power supply that didn't keep the voltage. I replaced it and now everything is running perfectly.. you might have this problem use another psu and check to see if thats the prob.
                Project Strykr
                Car PC - Work Log
