minlogon experiment gone wrong for a sec
  • minlogon experiment gone wrong for a sec
    as you can see, i used the minlogon files and enabled it you might say, it works great, but the problem is that i wanted it to load faster so i went into the registry and changed the "Shell" key which is "Explorer.exe" to media portal, a nice media app from sourceforge...
    the problem is.. it works and loads on startup but keeps loading.. and loads multiple exe's of it.. thats the bad part..
    im thinking this could be program error or it just doesnt work the same as it usually does.. with winlogon.. idk.. weird problem..
    [FIX]
    i did finally fix the problem, i had radmin (remote admin) already on there, and i transfered explorer.exe to it.. and made it the same exe as mediaportal.. so it thought media portal was the shell and now it really loads the explorer.exe and it fixed all my problems.. (YOU BETTER have network access to the drive or your screwed) oh and ctrl alt del didnt work in that case either
    tell me what you think about this...
    So explorer only loads once but mediaportal loads multiple times? Can you try it with another exe like notepad. See if it loads notepad multiple times.
      idk if i want to.. its perfect now.. but i might i will tell ya what i get if someone else doesnt do it first..
      do you have aim.. what is your sn?
      can't pm or something email me it..
      syfenx [at] gmail.com
        that's weird... i've changed the shell before and never saw anything like that. there's also another registry value that makes XP reload the shell if it's shutdown, maybe if you change that value, although I don't get why it would reload it when the app is still running.
        EWF, HORM, MinLogon on XP.
        Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
        Win Embedded Std 2011 RC
        OCZ Vertex Turbo 30GB SSD
        Lilliput 629 Transflective, WRX Screen Mount
        BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
        VoomPC 2
          whats the reg entry for that??
            AutoRestartShell... under Winlogon
            VoomPC 2
