Anyone ever changed the hibernation Windows XP screen?
  • Anyone ever changed the hibernation Windows XP screen?
    I want to change the hibernation Windows XP screen, the one that shows the windows logo right before it goes off. Which unless you changed your boot screen, is the same one that comes up on boot.
    I had to change my boot screen to prevent the screen from rolling, so I was hoping this would do the trick, plus I think it would be cool anyway.
    Any ideas?
    thanks
    Round VIII - [IIIIIIIIII] 30% Have some parts for 300zx Sema car I don't own yet. Will have 10.4" & 7" screen, and more then you can believe. Will add updates to cleancustoms.com, will be sweet. My car is still same, but might change.
    this is very interesting, and something I want to do too.
    I did a quick google search and came by this link:
    http://biw.rult.at/tuts/chxpbootlogo.htm
    it seems very technical, but I'll sit down and read it later
    edit: it may be easier than it looks for just changing the pictures. if you wanted to change the orientation, etc, it looks like it gets harder and you'd have to use a hex editor.
    for now, get reshack http://www.users.on.net/johnson/resourcehacker/
    it's a freeware resource editor
    run it, open c:\windows\system32\ntoskrnl.exe
    it's going to be under the "bitmaps folder"
    and you can export the pictures, modify them, and replace them. remember to back up the original!s
      Here is a strange thing though, I have had this problem with the window scrolling or rolling during boot, and have tried alot of differnt boot options. I don't kow what the problem is because I have tried everything in the bios and boot options. I was hoping that if I changed the hibernating window, it would solve the same scrolling when going into hibernation that it used to do when booting up. Thanks for the info, Ill take a look at it and see what I can figure out.
      later,
      Kenny
        wish I could help you with that, but i don't have any experience with the lilli
          i would like this aswell
            Now that I think about it, when I was modifying my boot screen with that little software package, don't remember which one, it let you change all the graphics in that exe file. I remember that because I saw the word hibernation in one of those. Has anyone who has changed there boot screen in XP without using the kernel on boot, have a hibernating windows screen that shows you your boot screen? I tried to change my boot screen the supposed simple way, but that didn't work, so I had to use something else which is why I am asking. Let me try it on my win 2000 machine and see what happens.
              to a search there is a whole thread about this
              my destinator map resource down permanently
                Hope you find the thead on this, I would like to know how to change the screen as well. I've been searching on google for over and hour on this topic but no luck.
                Installed
                Asus A7N8X-VM - AMD Mobile Athlon 2400
                512 Ram - 60GB HD - Opus 150w
                Lilliput 7" - Rikaline 6010
                [00000000000001100010-] 98% Completed
                Check Out My Install!!!
                  I know, thats where I got the link to download the software. Not everyone on that thread was able to just add the switch /bootlogo /noguiboot (off the top of my head) when trying it on XP. Actually, it seems to be the people with Epia mobo's. On that same thread, there is a link to download a little software package that does it all, and its free, and that worked for me. It lets you modify every single little graphic, including the little slider thingy. The link is on post #41 for anyone that is having a problem and needs that.
                  So is there anyone that is NOT running an Epia but is running XP, that was able to add the switches to change there boot screen, and have that same graphic show up when they go into hibernation?
                  http://www.mp3car.com/vbulletin/show...t=xp+boot+logo
                    http://www.users.on.net/johnson/resourcehacker/ is the little free program!!!
                    RexBruMet Skin for FrodoPlayer
                    Nissan Aux-in MOD
                    Originally posted by bgoodman
                    We're an international forum, post in whatever langauge you like.
                      use reshacker to edit the hibernation part "bitmap 2"
                      Nissan Aux-in MOD
                        Isn't 'bitmap 2' just the hibernating scroll bar. I thouth about changing that but I'm not sure it will change the windows logo.
                        Btw: I don't think they were talking about resourse hacker.
                        Installed
                          If you would have clicked on the link, the free program would be http://www.belchfire.net/~userxp/booteditornew.zip. This is a litte program that is specifically designed to replace the boot logo by adding a different type of switch then what is talked about in the same thread I have referenced already, and where I got the info from the beginning. Click on the link before you tell me what I am talking about. It was a very simple program to use, choose your graphic and click make, and it modifies your ini file for you. I had to choose this process because nothing else would work, and it seems to be because of the M10000 series because others are having the same problem. I have resource hacker, and use it, and will try resource hacker when I get a chance. I never knew where to find the hibernation file on XP. Ill let you know if it worked out or not.
                          Kenny
                          Here is the thread about changing your boot screen.
                          http://www.mp3car.com/vbulletin/showthread.php?t=37954
                          Here is the link to the program if you didn't find it in the thread that makes it simple, or if you are having problems making a new boot logo
                          http://www.belchfire.net/~userxp/indexbe.htm
                            What about the resume from hibernation screen??
                              Check my post in this thread for a link to a very good hands on guide on howto change the bootscreen in the ntoskrnl file, it's not just a matter of changing bitmaps since you have to change the whole palette...
                              http://www.mp3car.com/vbulletin/show...2&page=2&pp=15
                              On my nlite'd system I don't get any shutdown/hibernate window, it's just a black screen, resuming from hibernate isn't that always the dull white stripes with the "resuming windows" text ?
                              /M
