any chance to "hide" windows
  • any chance to "hide" windows
    hi, i'm afraid it's not a so clever question, but: is there any chance to hide windows and start directly with the chosen front end? i mean, is there a way in order to do this:
    1. avoid all post text and messages to be shown (just black screen could be good),
    2. use a custom boot logo (i've already done this)
    3. enter directly the front end, without see any windows trace?
    thanx.
    Search on terms like "windows shell" or "using FP as shell". I'm not sure you can do everything you're asking, but you can do some of it.
    Want to:
      Yes you can do this, you cant even tell my carpc is windows as it boots straight into the frontend with no messages (apart from the boot logo of course)
      You need to tell Xp to autologin
      Set your shell to be your frontend rather than explorer
      There is a local policy setting to disable windows status messages ("Opening network connections" and all that jazz). Once activated nothing will be shown at all apart from the default background until the frontend has loaded
      Use TweakXP to change the default "login" background to black. This will mean after the boot screen all you will see is a black screen until your frontend appears.
      Easy as that!
      Destinator 3 For PC! - http://www.map-monkey.co.uk/
        look at: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
        and modify the Shell registry value to your front end. Make sure you've got a way to bring up explorer or a command line once you make this change.
        EWF, HORM, MinLogon on XP.
        Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
        Win Embedded Std 2011 RC
        OCZ Vertex Turbo 30GB SSD
        Lilliput 629 Transflective, WRX Screen Mount
        BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
        VoomPC 2
          thanx alot. quick, sharp and clear!
          only a little doubt: how about hiding motherboard post messages (press del to enter setup, irq listing and so on ... without having to delay monitor power on, i mean...).
            your bios may have a "silent" boot option where it displays an image rather than the post messages. mine has it, but intel recommends not using it if you want the fastest boot possible. some even let you change the image.
            VoomPC 2
              any idea how to get back into explorer.exe?
              1990 Jeep Cherokee
              2000 VW Golf TDI 4dr
              2005 VW GTI MKIV - SOLD
                just tell your frontend to open explorer.exe as an app
                or use the task manager to run it
                [H]4 Life
                I'm a lesbian too.
                I am for hire!
                  careful tho if your using minlogon.exe CTRL, ALT, DEL will be disabled.. so make sure your front end has a shell capability.
                  Progress [I will seriously never be done!]
                  Via EPIA MII
                  512MB RAM
                  OEM GPS (embedded)
                  nLite WinXP pro on
                  1GB Extreme III CF card
                  Carnetix 1260 startup/ DC-DC regulator
                  Software: Still, re-Writing my existing front end in .Net
                    hmm il have to try that on my laptop im albout ready to load linux on so it wont matter if i jack it up.
                    if i do that and it dont work would safe mode work? or would that go to the Front end to?
                    Would their be any proformance gains by not loading explorer?
                    Hmm the big question, What front end to use lol.
                    1990 Jeep Cherokee
                      http://www.mp3car.com/vbulletin/showthread.php?t=38179
                      [M10K][TinyXP][Roadrunner Frontend][OEM Enclosure]
                      [iGmon]
                      Download MP3 MixTapes
