Nlite Xp Pro sp2 and Phone Control-help
  • Nlite Xp Pro sp2 and Phone Control-help
    ok, i have read as much as i could, nlited xp pro sp2 for about 8 times now different settings including the one i found here, still i cant make phone control to work? has anyone been able to make phone control work on an nlite xp pro? one extra question, i tried minlogon and figured what it does, but what is EWF? what does it do? thanks
    7" Lilliput
    Opus 150
    mini itx 1Ghz
    1GB sdram
    97 Prelude
    EWF=Enhanced Write Filter. Filters out any writes made to a volume and keeps them in memory (or in a hidden partition). Mainly used for flash memory installations which have limited number of write cycles.
    EWF, HORM, MinLogon on XP.
    Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
    Win Embedded Std 2011 RC
    OCZ Vertex Turbo 30GB SSD
    Lilliput 629 Transflective, WRX Screen Mount
    BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
    VoomPC 2
      thanks for the ewf info, so if i use my 3.5 hard drive i dont need that right!?! so that leaves me down to one last issue, does anyone have an nlite config that will make phone control work? heeellllpppp!!!
      7" Lilliput
      Opus 150
      mini itx 1Ghz
      1GB sdram
      97 Prelude
        after so many trials today, and still no success, what the heck is are the files required to make phone control work? frustrating totally, anybody answers please!!!!!
        7" Lilliput
        Opus 150
        mini itx 1Ghz
        1GB sdram
        97 Prelude
          I read somewhere that .NET framework, which Pho Co is based on, requires authentication which Minlogon cannot provide...
            No. Your wrong minlogon logs on tot he machines default user, which would still have .net framework enabled. I'm able to use my front end which is written in .Net with my minlogon enabled system. It's definatly a nlited system problem
            Progress [I will seriously never be done!]
            Via EPIA MII
            512MB RAM
            OEM GPS (embedded)
            nLite WinXP pro on
            1GB Extreme III CF card
            Carnetix 1260 startup/ DC-DC regulator
            Software: Still, re-Writing my existing front end in .Net
              well, I guess the obvious questions is: does he even have .NET installed??
              VoomPC 2
                yeh .net1.1 from microsoft. when installed on a non nlite OS (same computer) it works fine, but with nlite, i get errors.
                7" Lilliput
                Opus 150
                mini itx 1Ghz
                1GB sdram
                97 Prelude
                  Which version of .NET Framework is it??? Phoco needs 1.1.4.3 or similar to that, the Windows XP version is normally 1.1 only.
                    Also did you download and install the .Net redistributable from M$ ?
                    does your nLite have:
                    DTC, DCOM, COM+ services ?
                    Via EPIA MII
                    512MB RAM
                    OEM GPS (embedded)
                    nLite WinXP pro on
