Optimizing XP MCE
  • Optimizing XP MCE
    Well, I finally got my system together and running. It's still a little buggy, but it works none the less.
    One problem I've been having in particular is OS optimization.
    I've used Nlite to cutdown the OS. But for some reason I can only get it down to 420MB. Size is a factor because I'd like to be able to install it on a 512mb Compact Flash Card. I've used minlogon and bootvis and my boot times are still up at 30+ seconds.
    If anyone has any suggestions or an nlite setting file that can help me to cut it down more, or anything to help boot times, help would be appreciated.
    The system I'm running is as follows
    Windows XP MCE 2005
    1500+ Athlon 4 Mobile
    256mb PC2100 DDR
    133mhz bus (as reported by bios)
    10GB 7200RPM Western digital HDD
    Sound Blaster Live! Value
    ________________________________________________
    Worklog
    K7VTA3
    510mb PC3200 DDR
    ATI Radeon 7000 64mb
    [||||||||||] 95% Complete
    RentATechnow.com
    i don't think you'll get MCE much smaller than that. i'm running it on my desktop system and it's a bit of a hog (just the MCE part, the rest is just XP Pro), so I think 30 second boot is the best you'll get. i'm assuming you've gone through all the usual optimization steps like tweaking services, etc. right? i don't think MCE is the best choice for a CarPC system.
    EWF, HORM, MinLogon on XP.
    Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
    Win Embedded Std 2011 RC
    OCZ Vertex Turbo 30GB SSD
    Lilliput 629 Transflective, WRX Screen Mount
    BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
    VoomPC 2
      Yah, I did optimize all my services, etc.
      The only reason I'm stuck with MCE is because of the remote I'm using. It only works with MCE. Anyone know any way to make it work not using MCE or to cut out the media center part so I just have mce and allow the remote to work? That way I could use a different front end with my remote.
      Worklog
      K7VTA3
      510mb PC3200 DDR
      RentATechnow.com
        Try to use girder with the remote. If it works in MCE, then it will work in PRO.
        PowerVoice v1 | NaviVoice Source
        GammaControl v2.4
        SKINbedder v3
        1995 Lexus SC300
          Since I don't know what that is. . . I guess I'll have to for it
          Edit:
          I just looked it up. So, girder allows me to use the MCE remote with any operating system and remap the buttons to perform the functions I want?
          Worklog
          K7VTA3
          510mb PC3200 DDR
          RentATechnow.com
            Girder is basically an app that allows you to control a lot of system functions using different things. For example you could hack up a trackball mouse to be your volume controller. But for you, you'd just need to configure it to use your remote
            GammaControl v2.4
            SKINbedder v3
            1995 Lexus SC300
              wow, very useful. . . thats awesome!!! I could use this to control my volume from a knob!
              But will it work for the MCE remote? From what I have seen, other versions of windows don't have the proper drivers to use the remote.
              According to their website it will work. So I'm buying it. I'll let you know how it goes. Thanks
              Worklog
              K7VTA3
              510mb PC3200 DDR
              RentATechnow.com
                With Girder, you don't need drivers for the remote. Girder becomes the driver. Then you are able to use frotnends like Frodoplayer or RR with the remote.
                GammaControl v2.4
                SKINbedder v3
                1995 Lexus SC300
                  Thanks!! I just bought it. Sounds like a worthwile product. I'll let you know how it goes.
                  Worklog
                  K7VTA3
                  510mb PC3200 DDR
                  RentATechnow.com
                    Have fun configuring it
                    GammaControl v2.4
                    SKINbedder v3
                    1995 Lexus SC300
                      Yah, seems to be pretty str8 forward after you read the intro on the online help.
                      Worklog
                      K7VTA3
                      510mb PC3200 DDR
                      RentATechnow.com
                        Now there's an interesting idea... Must go investigate...
                          Yep. A member has done it. Forgot the name though. He's got an MR-2 Spider.
                          GammaControl v2.4
                          SKINbedder v3
                          1995 Lexus SC300
                            I have 2 tiny trackballs lying around. I had given up on them since I went the touchscreen route. But suddenly they are far more interesting again . I'm pretty sure I can write the software to interface with them too since it's just an input device.
                              Yep
                              GammaControl v2.4
                              SKINbedder v3
                              1995 Lexus SC300
