EWF with XP
  • EWF with XP
    I whant to use ewf with xp pro. I dont whant to use ram cache, I whant disk cache. How can i do it?
    not with EWF.
      Why? EWF supports disk overlay mode. But how can i enable it on normal xp?
        Yes, you can use EWF with WinXP (even Pro). Search the forums:
        http://www.mp3car.com/vbulletin/sear...earchid=823878
        However, since you whant a disk cache, not a mem cache nor a black-hole wash machine you are outta luck.
          LagunaICE:
          ssmaxss: hey man, i've been meaning to look into configuring disk overlay mode but it's a bit more complicated because that's typically set up by First Boot Agent in XPe. It needs to create a hidden partition on your drive and all that stuff. I recommend you look into the EWF API DLL. There's a "ConfigureEWF" function or something similar that I think does all the setup. It'll probably take a lot of tinkering in Virtual PC.
          EWF, HORM, MinLogon on XP.
          Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
          Win Embedded Std 2011 RC
          OCZ Vertex Turbo 30GB SSD
          Lilliput 629 Transflective, WRX Screen Mount
          BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
          VoomPC 2
            What ewf api dll do you mean? ewfapi.dll or ewf apifrom ewf sdk?
              the API dll that comes with the XPe tools. There's no EWF SDK that I know of.
              Here's the function you want to use: http://www.msdn.microsoft.com/librar...nfigureEwf.asp
              The best way to go about this is use the XPe tools to create an image with disk overlay, then load it into Virtual PC to see what the FBA registry values are so you can copy them over to your XP Pro system, then run ConfigureEwf. Looks pretty simple once you get the registry values.
              VoomPC 2
                I know ho to do it! Have anyone got EWF API SDK and ewf files from xpe sp2? (I have only sp1). Please send them me. I need all ewf*.dll ewf.sys ewfmgr.exe + ewf SDK.
                  Hm... I have copied registry values, runned ConfigureEwf and nothing happens...
