nlite errors
  • nlite errors
    this is my first attempt at using nlite.
    i used the settings for nlite similiar to the post a while back about the safe nlite settings, but during the instalation i got some missing files errors and gives me a dialog box to search for those files. are those supposed to come up because you remove a lot of things that the setup is looking for, or does that mean there is something wrong?
    I wish i knew how to do fiberglass work...
    Hi,
    What version of nLite are you using??? The settings.ini posted by Intellaworks are for version 0.98 beta 5 I think which will no longer work if you have just downloaded the latest version from http://nuhi.msfn.org .... sorry.
      u was using the latest version. I went through each setting individually and checked everything that was in the ini file.
        Hmm, did you have a previous version installed at all?
          i just rechecked, they werent the settings from intellawork, they were the modified settings by turbochris that were posted later in that thread.
            ill post the files the instatlaion cant find, most of them occurr in the screen about finding and installing the mouse and keyboard stuff.
            kodak_dc.icon
            srgb.icon
            streamci.dll
            tosdvd.sys
            tsbvcap.sys
            usbcamd.sys
            usbcamd2.sys
            vdmindvd.sys
            wowfax.sys
            wowfaxui.dll
            usrcntra.dll
            usrcoina.dll
            usrdpa.dll
            usrdtea.dll
            usrfaxa.dll
            usrlbva.dll
            usrmlnka.exe
            usrrtosa.dll
            usrsdpia.dll
            usrshut.dll
            usrsvpia.dll
            usrv42a.dll
            usrv80a.dll
            usrvoica.dll
            usrvpa.dll
            and after i skip the the instalaion of these files, the mouse drivers are screwed up and dont work. these are all from the turbochris's safe settings that were based off of intelleworks safe settings, but for the new nlite.
            any ideas?
              i am using the same setting as you are, window install fine, no missing files at all.. what xp are you using? I am using xp+sp2
                im using windows xp sp2 build 2180
                  If I were you restart with a clean install of nLite and XP Source.
                  This should then resolve most problems.
