Hey guys check this out 49 meg xp
  • Hey guys check this out 49 meg xp
    http://www.msfn.org/board/index.php?...pic=47480&st=0
    it is for real
    Giving it a go now But doubt it will be all that usable really.
      I wonder how fast this would boot!!! Keep us posted...
      also please try as much as you can for compatibility on this system
      Road Runner (winamp)
      Frodo
      FreeDrive (Destinator)
      Phoco (.NET)
      etc?
      If you have time of course!
      Roy
      2005 Range Rover 4.4
        I doubt Phoco will work on it tbh on an install footprint of 49Meg, I doubt most of the things we use won't work.
          The guy in that forum is working hard on it he already has made a batch file for it and a list of removable items after you apply a reg patch. He now needs an installer so this will boot up into a complete working OS. If anyone has any ideas on an installer for this please let him know. This is a very exciting project that many will benifit from
            what sort of installer???
              Please check out his thread it will explain more in detail the things he is working on. If I try to explain it I may say something wrong.
                God I love these guys.. I used there forums to made my own unattended XP install..
                  Hmmm.... looks neat... would it work with any front-end / drivers etc...??
                  List of front-ends/usefull apps
                  XTroniC | XTroniC Direct
                    Thats the problem... My nLite install gave me all sorts of errors so for now I've given up on nLite all together....
                    This 49mb install I'm even more skeptical about what it could be used for!!!
                    Roy
                      It has only errored because you have removed stuff needed for various applications. It takes more than one attempt to get it right ... I think I took about ten or so builds till it was perfect.
                        I went through the process to remove the files that the forum post recommends AFTER applying the registry settings and upon reboot Win XP gave me all sorts of missing file errors. So if you think that you can just apply the reg patch and then remove the files from XP and -Viola! you have a pruned XP system- Think again. You will blow your OS out of the water! I did. Luckily , I already have a small nLited Xp install so it was just a matter of reinstalling that - took 8 minutes or so . No biggie.
                        I have my install down to about 775 meg with no pagefile. I am hesitant in removing more components.
                          My Nlited XP install was just under 200Meg and everything except Speedcam alerts in Mapmonkey worked. I never used .NET apps so didn't need the .NET Framework installing.
                            Definitely! But I just never had time for 10 nlite tries..
                            Roy
                              Yup, or 100..takes time my friend.
