how to make nlite bootable CD
  • how to make nlite bootable CD
    ive tried to make a nlited version of XP buty im having a few problems. i made the nlite iso and burned it but my comp wont recognise it as a bootable CD. in fact windows wont even read the disk at all. how are u guys doin it??
    how did you burn it?
      just burnt the iso file using nero. ( didnt just burn the winlite.iso file to a CD in case thats what u mighta been thinkin)
        use nero and select "burn image" from the file menu
        then nero will recognize the files inside and automatically burn it to a CD
        [||||||||||||||||||||] - final touches
        SUPER 7" VGA w/ TS
        Toshiba Satellite 3000
        P3 850
        256MB
        30GB
        Geforce2 Go
        DVD
        Orinoco 802.11b PCMCIA
        nlite WinXP 350MB installed
        RoadRunner
        iGuidance 2.1
        Holux GM210 GPS
        Xantrex Xpower 300
          yeah thats what i did. btw before i made the ISO i checked the folder to see what i had been left with and the olny files in there were
          I386 (folder)
          boot.bin
          WIN51
          WIN51P
          win51ip.sp2
          and thats all does that sound right?
            anyone? my guess is no bacause theres no exe files or anything but i followed nlite through step by step and thats what i ended up with so i dunno who to get it to be bootable or even readable
              you do`t need an exe file
              i think your problem is your burning methode
              http://unattended.msfn.org/global/finish.htm
              qoute
              Make sure you burn the ISO using Disc-at-once in your burner options, rather than Track-at-once. Because this usually helps resolve bootability issues or file copy errors.
              /qoute
                You dont run your nLite XP cd from windows, you set your bios to boot from cd first and install it that way.
                  and during the installation, you can just choose to reinstall windows, so you don't lose any of the other program data
                  SUPER 7" VGA w/ TS
                  P3 850
                  256MB
                  30GB
                  Geforce2 Go
                  DVD
                  RoadRunner
                  iGuidance 2.1
                  Holux GM210 GPS
                  Xantrex Xpower 300
                    yeah the problem is no matter how many times ive tried i cant make the CD boot. ive done a one to one copy of my disc and it will boot from the disc no worries but i cant get my nlited one to boot. i looked at the disc in isobuster and it shows the disc is bootable so why wont it boot?
                    i know its a long shot but anyone got a nlited XP iso they can uplaod somewhere so i can burn it and see what happens?
                      and if you make a bootable disk youself.( see the link i gave you before)
                      does it then works?
                        I had a friend go through a similar situation. The only soultion we can com eup with is that his version of windows is hacked and thats what is possibly causing the cd iso to be made incorrectly. I even went as far as creating a cd for myself right next to his comp doing the exact samething and mine is fine and his is not working.
                        Computer:
                        COMPLETE SYSTEM OVERHAUL!!!!!!
                        STAY TUNED IN THE UPCOMING WEEKS!
