TinyXP Rev04 + FrontEnds
  • TinyXP Rev04 + FrontEnds
    FYI for u guys, this was just released on the April. 14th
    http://www.retestrak.nl/Board/index.php?showtopic=13355
    ***UPDATE***
    Ok i played with this build over the weekend and so far so good...i currently have all this workin:
    - VIA M10K MotherBoard w\ all drivers(Video,LAN,Audio,4in1pack)
    - Hibernation
    - Road Runner[5-2 Build]
    - Wireless
    - WinTV FM drivers + FM APP[works in RR to]
    - USB-UIRT (w/Jenson IR20 remote)
    - Girder 4
    - Xenarc 700TSV TouchScreen Drivers
    - iGuidance 2.1.2NA
    - iGMod Preview 4*
    - WMP10*
    - Real\Quicktime Alternative*
    Current Install footprint 435MB [For Hibernation add 435MB + the amount of RAM installed in your carPC]
    The more things i test, ill update this thread
    ***INSTALL NOTES***
    -Required for WMP10[Regular Full Install] on this build-
    You need to install wmploc.dll to your sys32 directory. You can find this file HERE. Then download and install WMP10. Download it HERE
    -Required for Light Non-standard WMP-
    This package can install the Windows Media codecs. A second feature is that it can give you the ability to play Windows Media in your browser without the need to install Windows Media Player. Download itHERE
    -QuickTime Alternative-
    QuickTime Alternative will allow you to play QuickTime files without having to install the official QuickTime player
    Advantages compared to using the QuickTime Player:
    -Quick & Easy Install
    -Its easy to make a unattended installation
    -No background processes
    -Use a player of your own choice
    -Low on Resources
    -Small Size
    Download it HERE
    -RealPlayer Alternative-
    Real Alternative will allow you to play RealMedia files without having to install the official RealPlayer
    Advantages compared to using RealPlayer:
    -Proper Uninstallation
    -Low on Resources
    -No Advertising, No Registration forms, nothing annoying
    Download it HERE
    *newest install updates
    [M10K][TinyXP][Roadrunner Frontend][OEM Enclosure]
    [iGmon]
    Download MP3 MixTapes
    The link doesn't work, need to be signed in
    The old setup http://flickr.com/photos/ilyassx
    The new setup http://my.opera.com/ilyassx/albums/show.dml?id=110701
    Jetway J7F2WE VIA C7 1.5 GHz
    512 DDRII 533
    3.5" SATA2 H.D.D 200GB
    M1-ATX
    ELM327MS OBDII
    Creative Audigy 4
    PROGRESS:[########-]90%
      This is the info about the new build *from the site listed above*
      eXPerience Presents...
      Windows TinyXP Professional SP2 Revision 04 Unattended CD
      This revised edition of TinyXP combines the small size of
      older versions, but with almost all of the functionality
      of later versions. This is primarily a fast gaming OS
      There are no Microsoft games in this edition.
      There are no third party programs included in
      this edition. You are however still able to open
      zip files, they will have a normal yellow folder
      but with a zip.
      There are no languages left apart from US English.
      The keyboard layout is United Kingdom, system locale and
      timezone are also set for the UK. This can be changed in
      Regional and Language Options in Control Panel - all
      "keyboard layouts" are left in.
      There are no networking command line tools - this increases
      security dramatically and stops businesses from using
      TinyXP for their networking. If you're running a business
      then hey - BUY WINDOWS XP. I have no sympathy with you
      people.
      It is important to note that TinyXP started out as a
      gaming OS that you can surf the net with, and use most
      programs with it. It ended up revised to the point that
      you might as well use normal XP. This however was always
      because it fully supported networking when it didn't need
      to for the purpose it was meant for - home use.
      In this edition, netstat.exe and other command line
      networking tools and a few more networking type features
      are now removed, TinyXP is back again to a very small
      footprint (365Mb), a very fast install (7 minutes) and
      uses far less RAM than Rev03 did - about 20Mb less.
      This edition has Internet Explorer included, (not just
      the core but the whole explorer). It also includes the
      DHCP service, Wireless LAN drivers and is still compatible
      with "Microsoft Office" and supports printers, joysticks,
      firewire etc.
      HINT: If you are in any doubt about the functionality
      of TinyXP Rev04 - get hold of a program called "VMware"
      and install TinyXP into VMware - this only takes about
      as long as an install on your real PC would.
      Then install "VMware tools" in VMware and drag whichever
      programs into VMware you need to install them and give
      the operating system a complete test before you actually
      use it.
      This edition DOES NOT work with "Sisoft Sandra".
      Sisoft Sandra seems to rely on a lot of Windows components,
      it was not worth the extra RAM and hard drive space needed,
      just to support Sisoft Sandra.
      This ISO is designed to be the ULTIMATE TinyXP, being
      very small and VERY fast, whilst still giving you the
      full functionality (almost) of normal XP - but without
      as many networking features.
      This edition does include "Active Directory" and basic
      networking between two PC's will work fine, as long as
      you enable "Simple File Sharing" under "Folder Options"
      in "Control Panel". This "Simple File Sharing" is
      disabled in this edition, so you can access the
      "Security" tab on your file and folder properties.
      EXE File Size in Bytes.......................... 127,774,258
      Extracted ISO File Size in Bytes............ 152,016,896
      Files on ISO........................................ 2,320
      Folders on ISO..................................... 86
      SHA-1 Checksum utility (fsum.exe) is provided with a
      batch script to check the EXE file and the ISO file.
      You must of course extract the ISO file from the EXE
      file to check the ISO checksum!
      The checksum codes for both the EXE file and the ISO file
      can be found at...
      Look under the section called Releases Only (P2P) and find
      the thread for TinyXP Rev04.
      If any of the above sizes, file & folder totals, or SHA-1
      checksums are different to what you have, DO NOT USE THIS
      EXE OR ISO FILE! You have a fake (repackaged) eXPerience
      release! Most probably repacked with a trojan, or other
      malicious worm/virus/rootkit.
      Windows Performance Info...
      Operating System RAM Memory Usage = 45Mb (▒ 5Mb)
      WINDOWS Folder = 366.2Mb
      Running Processes on First Install = 14
      Install Time for Windows = Seven Minutes
      Windows XP Pro Custom Added Features
      eXPerience Spectrum Wallpaper
      Integrated Service Pack 2 (WindowsXP-KB835935-SP2-ENU.exe)
      Registry Tweaks For Performance/Gaming/Internet
      Windows Media Center 2005 Beta Version Theme (Royale)
      Integrated Critical and Recommended Post SP2 Hotfixes
      (Windows Updates) up to 28th March 2006...
      IE6.0sp1-KB905915-Windows-2000-XP-x86-ENU
      WindowsInstaller-KB893803-v2-x86
      WindowsXP-KB873333-x86-ENU
      WindowsXP-KB873339-x86-ENU
      WindowsXP-KB883939-x86-ENU
      WindowsXP-KB884020-x86-enu
      WindowsXP-KB885222-v2-x86-ENU
      WindowsXP-KB885250-x86-ENU
      WindowsXP-KB885835-x86-ENU
      WindowsXP-KB885836-x86-ENU
      WindowsXP-KB886185-x86-enu
      WindowsXP-KB886677-x86-enu
      WindowsXP-KB886716-v2-x86-ENU
      WindowsXP-KB887472-x86-enu
      WindowsXP-KB887742-x86-ENU
      WindowsXP-KB887797-x86-enu
      WindowsXP-KB888113-x86-ENU
      WindowsXP-KB888240-x86-ENU
      WindowsXP-KB888302-x86-ENU
      WindowsXP-KB889527-v3-x86-ENU
      WindowsXP-KB890046-x86-ENU
      WindowsXP-KB890175-x86-ENU
      WindowsXP-KB890859-x86-ENU
      WindowsXP-KB891781-x86-ENU
      WindowsXP-KB893066-v2-x86-ENU
      WindowsXP-KB893086-x86-ENU
      WindowsXP-KB893357-v2-x86-ENU
      WindowsXP-KB893756-x86-ENU
      WindowsXP-KB894391-x86-ENU
      WindowsXP-KB894395-x86-ENU
      WindowsXP-KB896344-v2-x86-ENU
      WindowsXP-KB896358-x86-ENU
      WindowsXP-KB896422-x86-ENU
      WindowsXP-KB896423-x86-ENU
      WindowsXP-KB896424-x86-ENU
      WindowsXP-KB896427-v3-x86-ENU
      WindowsXP-KB896428-x86-ENU
      WindowsXP-KB896626-v2-x86-ENU
      WindowsXP-KB898461-x86-ENU
      WindowsXP-KB898900-v2-x86-ENU
      WindowsXP-KB899587-x86-ENU
      WindowsXP-KB899589-x86-ENU
      WindowsXP-KB899591-x86-ENU
      WindowsXP-KB900725-x86-ENU
      WindowsXP-KB900930-x86-ENU
      WindowsXP-KB901017-x86-ENU
      WindowsXP-KB901190-x86-ENU
      WindowsXP-KB901214-x86-ENU
      WindowsXP-KB902400-x86-ENU
      WindowsXP-KB903234-x86-ENU
      WindowsXP-KB904706-v2-x86-ENU
      WindowsXP-KB905414-x86-ENU
      WindowsXP-KB905749-x86-ENU
      WindowsXP-KB905915-x86-ENU
      WindowsXP-KB908519-x86-ENU
      WindowsXP-KB908521-x86-ENU
      WindowsXP-KB910437-x86-ENU
      WindowsXP-KB911927-x86-ENU
      WindowsXP-KB912919-x86-ENU
      WindowsXP-KB913446-x86-ENU
      Enjoy this fine release from eXPerience
      Build Date: 13.04.2006
      Release Date : Spring 2006
      [iGmon]
        Originally posted by camsgs3
        Here is the link to DL,
        of later versions. This is primarily a fast gaming OS.
        but with a zip.
        people.
        firewire etc.
        use it.
        can be found at...
        Good but you have to remove the torrent link (offence to Forum Rules)
        Cheers,
        512 DDRII 533
        M1-ATX
        ELM327MS OBDII
        Creative Audigy 4
          removed, if u didnt get it.. just sign up at the site
          [iGmon]
            Thanks man, i will
            512 DDRII 533
            M1-ATX
            ELM327MS OBDII
            Creative Audigy 4
              i tried it and installed frodoplayer
              but it didn't work because it could'nt connect to database
              it has something to do with MBAC, that is missing
              i would also like to now if its possible to hibernate in versions of tinyxp
              anyone??
                Not tested yet
                512 DDRII 533
                M1-ATX
                ELM327MS OBDII
                Creative Audigy 4
                  Well I just tried it with RR. It works, although I had heaps of problems trying to install drivers. Even got a BSOD. Touch screen wan't detected )might be due to driver problems) and there IS NO HIBERNATION. This is a deal killer for me. I was hoping to see real fast resuming.....Oh well.
                    ahhh that sucks,does anyone know if we can add it to this build?
                    [iGmon]
                      no doubt it can be added. You would probably need to ask the guy "eXperience" on the forum mentioned above.
                        yea i did already, waitin for his response back....check this thread out in the meantime
                        http://www.mp3car.com/vbulletin/showthread.php?t=74536
                        and someone see if that works
                        [iGmon]
                          I'm using this and I'm able to use hibernation...just needed to update my video drivers like always.
                            yep, just did the same...workin fine now
                            [iGmon]
                              the last version of his I installed, wireless didnt work...kind of an important thing...hopefully that is fixed
                              As of 4/15/06: Computer is in and running great! Still got a few bugs to work out tho
                              M10000, Lilliput, M1-ATX, Slot DVD, 40 GB HDD, 512 MB DDR, BU-353, M$ S&T '06, XMD1000
