eWF and Documents And Settings
  • eWF and Documents And Settings
    For some reason some software when installed, data files are installed into the Local Settings directory under the user profile in Documents And Settings.
    I have ewf protecting drive c:, while drive D: is unprotected and any file I copy to it stays there.
    This means that anytime something changes, it is lost the next time you boot your computer.
    Is there a workaround for this? My problem is my gps software installs the data files in Local Settings/../Garmin and every route or waypoint I put in, is lost.
    I think it can be done if Windows can be tricked so that Local Settings folder is in the D: drive instead of the protected C: drive.
    Another way is to disable protection on Local Settings folder in C: using ewf, I dont know if it can be disabled on just one folder.
    I dont know how to implement either solution, is there another way?
    New Lilliput EBY701 For Sale http://www.nusantech.com/index.asp?c...at=TOUCHSCREEN
    SiRF3 Bluetooth GPS http://www.nusantech.com/index.asp?cat=GPS
    Look for settings in your GPS software, you may be able to dump the files it creates to a different directory. If all else fails install the whole GPS app on your D drive
      I think this may be what you are looking for:
      http://www.winguides.com/registry/display.php/107/
        blk02si: yea i've installed the software on unprotected D drve but it still won't remember last waypoints etc. I suspect its in the registry or local settings.
        jackboot: i'll try that when I get home. I think that maybe what i'm looking for.
          I tried the registry thing, but it doesnt work. It resets to default c: when I reboot. eWFmgr c: is disabled.
          I even ran auto-it to set the registry to D: drive right after booting into windows, it changed to D: in the registry, but the data files in D: is still untouched, it still uses the one in Documents And Settings\user\Local Settings\Application Data etc
          It would be awesome if it worked. Does anybody know why it didnt?
          Btw, everytime I load frodoPlayer, application data changes back from d:\masch\documents and settings\masch\local settings\application data to c:\documents and settings\masch\local settings\application data. Does anyone know a reason for this?
            how did you disable EWF?
            EWF, HORM, MinLogon on XP.
            Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
            Win Embedded Std 2011 RC
            OCZ Vertex Turbo 30GB SSD
            Lilliput 629 Transflective, WRX Screen Mount
            BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
            VoomPC 2
              command prompt
              c:\ewfmgr c: -live -commitanddisable
              and then
              c:\ewfmgr c: -disable
              just to be sure. Why do you ask?
                Anyone with any other ideas? I downloaded TweakUI from Microsoft Power Toys but it doesnt have an option for Application Data.. only for My Documents
