Error installing .Net framework 1.1.4322
  • Error installing .Net framework 1.1.4322
    Hi!
    Im having a problem installing .Net framework on an nLited winxp version.
    The error occurs right after the install program has extracted its files and is ready to begin. Since i have a norwegian version of Windows, ill have to translate it as good as i can:
    "The installation program for Microsoft .Net Framework can not write to the installation log."
    I click "OK" and the installation stops.
    I tried using the "dotnetfx.exe /T:<temp folder> /C" switches, and the installation started and finished without errors.
    Next I tried to install Centrafuse 1.6, but the installation program said that it needed .Net Framework 1.1.4322 to continiue. The same message you would get without having .Net installed at all.
    So I guess the problem is with the install log issue?
    Here is a cutout of the most relevant information from the nLite latest session file for the windows installation i used. Is there anything in this config that can be the source of the problem?
    (still in norwegian but i guess you recognise most of it)
    ;# Operativ System Innstillinger #
    Color Schemes
    Disk and Profile Quota
    Diskopprydding
    Document Templates
    FAT to NTFS converter
    Fil og Oppsettguide
    Hjelp
    Input Metode Editor
    Jet Database Engine
    Manuell Installering og Oppgradering
    MS Agent
    Oppgave Planlegger
    Private Character Editor
    Remote Installation Services (RIS)
    Sikkerhets Senter
    Skrivebord Oppryddings Veiviser
    Søke Assistent
    Tur
    User Account Pictures
    Ut av Boks hendelse
    Web Visning
    Zip Kataloger
    ;# Service #
    Advarsler
    Autoupdate
    Avbruddsfri Power Supply
    Beep Driver
    Faks Service
    Feilrapportering
    Fjerninnstill Register
    Flyttbar Lagring
    Imapi
    Indekserings Service
    Messenger
    System Gjenoppretting
    Telnet Server
    Terminal Service
    Volume Shadow Copy
    WebClient
    Windows Tid
    ;# Compatibility #
    Compat02
    Compat06
    Compat12
    [KeepFiles]
    msconfig.exe
    [RemoveFiles]
    blastcln.exe
    clock.avi
    [Options]
    ClassicSetup
    BlackSetupBack
    GuestName = ""
    AdminName = ""
    ProfilesDir = "%SystemDrive%\Documents and Settings"
    TargetPath = "OS"
    temp_dir = %USERPROFILE%\Lokale innstillinger\Temp
    AdvTweaks
    isovol = WinLite
    isoatt = -allow-multidot -relaxed-filenames -allow-leading-dots -N -l -d -D -joliet-long -duplicates-once -no-emul-boot -b boot.bin -hide boot.bin -hide boot.catalog
    [Patches]
    TcpIp = 10
    UsbPoll = 125
    DoUxTheme
    DoSFC
    [Services]
    Themes,2
    StiSvc,3
    AppMgmt,3
    AudioSrv,2
    CryptSvc,2
    EventLog,2
    HidServ,4
    HTTP,3
    HTTPFilter,3
    IpNat,3
    NDProxy,3
    NetDDE,4
    NetDDEdsdm,4
    Netman,3
    PlugPlay,2
    ProtectedStorage,2
    SamSs,2
    seclogon,2
    SENS,4
    SharedAccess,2
    SysmonLog,3
    TapiSrv,3
    TrkWks,2
    Wmi,3
    xmlprov,3
    LanmanWorkstation,2
    RasAuto,3
    RasMan,3
    RemoteAccess,4
    IpFilterDriver,3
    IpInIp,3
    Ip6Fw,3
    ALG,3
    DHCP,2
    DNSCACHE,2
    PolicyAgent,2
    NLA,3
    LMHosts,2
    Browser,2
    NetLogon,3
    RpcLocator,3
    NtLmSsp,3
    LanmanServer,2
    After some reading around on the net i found that missing IIS is probobly the reason why .Net wont work.. ?
      I dont have IIS anywhere near my PC but I still have .net loaded both 1 and 2
      Visit my site V8 Scimitar
      SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit. 4 years installed and it just keeps running!
        I had this problem also....I finally got it to work by downloading an old version of 1.1 from some russian site...yes, I know....but it worked.
          .net error
          I had this same problem as well. I was using minlogon. I solved the problem by restoring winlogon, installed .net, then re-established minlogon.
          good luck
