minlogon and user profiles
  • minlogon and user profiles
    I understand that when you use minlogon, there is nothing to do with user profiles.
    However, since this is not a fresh XP install (on laptop or CarPC), I've been logging in as the Administrator. I've got the desktop and other things set-up as Administrator, but when I log in using minlogon, I'm not able to get those items without going through Windows Explorer.
    I understand that I could just transfer the user settings to the new user, but what's the new user if minlogon doesn't use users....?
    Anyone have any insight?
    Jan Bennett
    I don't know about all this. I do know one thing. When you use minlogon, it uses the System account, but I have no idea where that profile exists or if it even exists.
    I guess you could just play around with copying your profile over the "Default User" profile, or even the "All Users" profile. Probably would want to back them up first.
    EDIT: From the little bit of research I've just done on it, minlogon by default does not save settings or changes to the profile. I did come across something that said changing a registry key will take care of that, but I still have yet to find which reg entry will have to change. Hope that helps a little at least.
    Also, someone else tried to copy their profile over the "default user" and it didn't work.
    Tidder
    Try RevFE
      Unhide the profiles under Documents and Settings, after applying the minlogon stuff you will find some mopre user profiles, you can then copy stuff into them from your administrators account. Also check permissions though as you may not be able to get into the administrators account after applying minlogon, never tried.
        according to this it doesn't use profiles
        http://msdn.microsoft.com/library/de...E_MinLogon.asp
        Visit my site V8 Scimitar
        SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit. 4 years installed and it just keeps running!
          and that v8, is why I'm trying to figure out if there's an easier way to get all of my stuff over from my normal log in...
          Jan Bennett
            it's been a while, but it's either "All Users" or "Default User". can't remember for sure now...
            EWF, HORM, MinLogon on XP.
            Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
            Win Embedded Std 2011 RC
            OCZ Vertex Turbo 30GB SSD
            Lilliput 629 Transflective, WRX Screen Mount
            BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
            VoomPC 2
              easy enough!
              Thanks!
              Jan Bennett
