Trying to make tiny xp from my Windows XP Disc with nlite
  • Trying to make tiny xp from my Windows XP Disc with nlite
    I used the Tiny XP Guide from exPerience, and I keep getting this message in nLite, what am I doing wrong here? I'm using WinXP service pack 2 disc home edition.
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.IO.IOException: Cannot create a file when that file already exists.
    at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    at System.IO.__Error.WinIOError()
    at System.IO.FileInfo.MoveTo(String destFileName)
    at ..()
    at ..(Object , EventArgs )
    at System.Windows.Forms.Control.OnEnter(EventArgs e)
    at System.Windows.Forms.Control.NotifyEnter()
    at System.Windows.Forms.ContainerControl.UpdateFocuse dControl()
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.42 (RTM.050727-4200)
    CodeBase: file:///C:/WINNT/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
    nLite
    Assembly Version: 1.2.0.1
    Win32 Version: 1.2.0.1
    CodeBase: file:///C:/Program%20Files/nLite/nLite.exe
    System
    CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    nLite
    CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
    CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    cablib
    Assembly Version: 1.0.2459.36134
    Win32 Version:
    CodeBase: file:///C:/Program%20Files/nLite/cablib.DLL
    msvcm80
    Assembly Version: 8.0.50608.0
    Win32 Version: 8.00.50727.42
    CodeBase: file:///C:/WINNT/system32/msvcm80.dll
    nlgw
    Assembly Version: 1.1.0.0
    MCDBNET2
    Assembly Version: 1.32.0.0
    Win32 Version: 1.32.0.1302
    CodeBase: file:///C:/Program%20Files/nLite/MCDBNET2.DLL
    Accessibility
    CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
    ************** JIT Debugging **************
    To enable just-in-time (JIT) debugging, the .config file for this
    application or computer (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the computer
    rather than be handled by this dialog box.
    Here is the configuration script I'm using from LAST SESSION.INI:
    [Tasks]
    Remove Components
    Patches
    Tweaks
    Options
    [Components]
    ;# Applications #
    Accessibility Options
    Briefcase
    Charmap
    ClipBook Viewer
    Defragmenter
    Games
    Internet Games
    NT Backup
    Pinball
    Screensavers
    ;# Drivers #
    Asynchronous Transfer Mode (ATM)
    Cameras and Camcorders
    Display Adapters
    IBM Thinkpad
    InfraRed
    ISDN
    Logitech WingMan
    MultiFunctional
    Portable Audio
    Printers
    Scanners
    SCSI/RAID
    Sony Jog Dial
    Tape drives
    Toshiba DVD decoder card
    ;# Hardware Support #
    ATM Support
    Brother Devices
    Gravis Digital GamePort
    Logical Disk Manager
    Multi-port serial adapters
    Secure Digital host controller
    Smart Cards
    Sony Memory Stick
    Teletext codec
    Video Capture
    Windows CE USB Host
    Windows Image Acquisition (WIA)
    ;# Multimedia #
    AOL ART Image Format Support
    DirectX diagnostic tool
    Images and Backgrounds
    Intel Indeo codecs
    Luna Theme
    Media Center
    MIDI audio support
    Mouse Cursors
    Movie Maker
    Music Samples
    Old CDPlayer and Sound Recorder
    Speech Support
    Tablet PC
    Windows Media Player
    Windows Media Player 6.4
    Windows Sounds
    ;# Network #
    Client for Netware Networks
    FrontPage Extensions
    IP Conferencing
    MAC Bridge
    Map Network Drives/Network Places Wizard
    MSMail and MAPI
    MSN Explorer
    Netmeeting
    NetShell Cmd-Tool
    Network Monitor Driver and Tools
    Network Setup Wizard
    NWLink IPX/SPX/NetBIOS Protocol
    Peer-to-Peer
    Synchronization Manager
    Windows Messenger
    ;# Operating System Options #
    .NET Framework
    16-bit support
    Administrative Templates
    Administrator VB scripts
    Color Schemes
    Command-Line tools
    Desktop Cleanup Wizard
    Disk and Profile Quota
    Disk Cleanup
    Document Templates
    DR Watson
    File and Settings Wizard
    File System Filter Manager
    Help
    Input Method Editor
    Logon Notifications
    Manual Install and Upgrade
    MS Agent
    Private Character Editor
    Remote Installation Services (RIS)
    Save Dump Utility
    Search Assistant
    Security Center
    Service Pack Messages
    Shell Media Handler
    Task Scheduler
    Tour
    Web View
    ;# Services #
    Alerter
    Application Layer Gateway
    Autoupdate
    Background Intelligent Transfer (BITS)
    Beep Driver
    COM+
    Distributed Link Tracking Client
    Distributed Transaction Coordinator (DTC)
    DNS Client
    Error Reporting
    Event Log
    Fax Services
    Imapi
    Indexing Service
    IPSEC Policy Agent
    Management Instrumentation (WMI)
    Message Queuing (MSMQ)
    Messenger
    Network DDE
    Network Location Awareness (NLA)
    Performance Logs and Alerts
    QoS RSVP
    Quality of Service (QoS)
    Remote Registry
    Removable Storage
    Secondary Logon
    Service Advertising Protocol
    Shell Services
    SNMP
    System Event Notification (SENS)
    System Monitor
    System Restore
    TCP/IP NetBIOS Helper
    Telnet Server
    Terminal Services
    Text Services Framework
    Volume Shadow Copy
    WebClient
    Windows Firewall/Internet Connection Sharing (ICS)
    ;# Directories #
    DOCS
    SUPPORT
    VALUEADD
    ;# Compatibility #
    [KeepFiles]
    msconfig.exe
    [RemoveFiles]
    clock.avi
    [Options]
    CABRecompress
    ClassicSetup
    BlackSetupBack
    GuestName = ""
    AdminName = ""
    ProfilesDir = "%SystemDrive%\Documents and Settings"
    TargetPath = "WINDOWS"
    temp_dir = %USERPROFILE%\Local Settings\Temp
    isovol = WinLite
    isoatt = -allow-multidot -no-iso-translate -relaxed-filenames -allow-leading-dots -N -l -d -D -joliet-long -duplicates-once -no-emul-boot -b boot.bin -hide boot.bin -hide boot.catalog
    [Patches]
    TcpIp = 16777215
    UsbPoll = 125
    DoUxTheme
    DoSFC
    [Services]
    StiSvc,3
    AppMgmt,3
    AudioSrv,2
    CryptSvc,2
    HidServ,4
    HTTP,3
    HTTPFilter,3
    IpNat,3
    NDProxy,3
    Netman,3
    PlugPlay,2
    ProtectedStorage,2
    SamSs,2
    SCardSvr,3
    TapiSrv,3
    UPS,3
    xmlprov,3
    LanmanWorkstation,2
    RasAuto,3
    RasMan,3
    RemoteAccess,4
    IpFilterDriver,3
    IpInIp,3
    DHCP,2
    Browser,2
    NetLogon,3
    RpcLocator,3
    NtLmSsp,3
    LanmanServer,2
    Celeron 2.53 Ghz Processor
    512M ddr memory
    Mimo 7" USB Display
    XM Direct Tuner
    mp3car.com XM Direct USB interface box
    1999 Mustang GT Convertible Supercharged
    [Tweaks]
    Desktop-Internet Explorer icon-Hide
    Desktop-My Computer icon-Show
    Desktop-My Documents icon-Hide
    Desktop-My Network Places icon-Hide
    Desktop-Recycle Bin icon-Show
    Explorer-Add 'CMD Shell' to all Drives and Folders
    Explorer-Advanced Search: preconfigure options
    Explorer-Change Explorer Folder View to: details
    Explorer-Classic Control Panel
    Explorer-Disable Beep on errors
    Explorer-Disable Prefix: Shortcut to
    Explorer-Remove Send To on context menu
    Explorer-Show all files and folders
    Explorer-Show Drive Letters in front of Drive Names
    Explorer-Show extensions of known file-types
    Explorer-Show Full Path in Address and in Title-Bar
    Explorer-Show Statusbar in all windows
    Internet Explorer-Disable information bar when popup is blocked
    Internet Explorer-Disable Market Place bookmark
    Internet Explorer-Disable Media Player 6.4 created bookmarks
    Internet Explorer-Disable sound when popup is blocked
    Internet Explorer-Enable Google URL-Search
    Internet Explorer-Keep IE URL-History for-50 Days (max recommended)
    Internet Explorer-Set Homepage-www.google.com
    Internet Explorer-Set Internet Explorer to accept 10 connects at a time
    My Computer-Add Control Panel to Context Menu
    My Computer-Add Device Manager to Context Menu
    My Computer-Add Services to Context Menu
    My Computer-Add Software to Context Menu
    My Computer-Remove Shared Documents
    My Computer-Show details in Device Manager
    My Computer-Show non-present devices in Device Manager
    Network-Disable automatic search for network folders and printers
    Network-Disable restoring mapped network drives on logon
    Network-Disable Simple File Sharing
    Privacy-Clear most recently opened documents list on logoff
    Privacy-Disable and Remove Documents List from Start Menu
    Privacy-Remove Alexa Spyware
    Security-Always show Updates under Software
    Security-Disable Screensaver
    Security-Disable Web Open With prompt
    Speed-Disable Optimize harddisk when idle
    Speed-Disable Tracking of Broken Shortcut Links
    Speed-Do not cache thumbnails
    Speed-Use Windows classic folders / No Tasks Sidepanel
    Start Menu-Disable Highlight newly installed programs
    Start Menu-Disable popup on first boot
    Start Menu-Reduce popup delay
    Start Menu-Remove My Music
    Start Menu-Remove Search the Internet from Search
    Start Menu-Remove Set Program Access and Defaults
    Start Menu-Remove 'Windows Catalog' from Start Menu
    Taskbar-Disable Balloon Tips
    Taskbar-Disable Group similar Taskbar buttons
    Taskbar-Disable Hide inactive icons
    Visual Effects-Animate windows when minimizing and maximizing-Disable
    Visual Effects-Fade effect on menus and tooltips-Disable
    Visual Effects-Show shadows under mouse pointer-Enable
    Visual Effects-Show translucent selection rectangle-Enable
    Visual Effects-Show window contents while dragging-Enable
    Visual Effects-Slide open combo boxes-Disable
    Visual Effects-Slide taskbar buttons-Disable
    Visual Effects-Smooth edges of screen fonts-Enable
    Visual Effects-Use common tasks in folders-Disable
    [Unattended]
    UnattendMode = DefaultHide
    ComputerType = Automatic
    MaximumDataStorePercentOfDisk = 12
    ProgFilesPath = "C:\Program Files"
    [GuiRunOnce]
    [Drivers]
    [Hotfixes]
    512M ddr memory
    Mimo 7" USB Display
    XM Direct Tuner
      figured it out yesterday. It seems that the program I used didn't change the attributes from read only, so after changing attributes, the process worked great! Just have to install now.
      512M ddr memory
      Mimo 7" USB Display
      XM Direct Tuner
        Please provide an update on how it works - I don't think I'll ever do the nLite thing, but I figure the more feedback on how well it works the better
        Carputer Progress:
        Re-do fabrication of screen [DONE]
        Add mini-USB and micro-USB power from M2-ATX [DONE]
        Teardown PC [100%]
        Add HDMI > VGA converter [0%]
          Well, I just burned the cd today. I'm in the process of installing it on my laptop now. I'll post more when done. It cut the on-cd size down to about 235 mb. This is xp home service pack 2 that came witht the laptop. So far it has given me messages about some missing files on the cd.
          512M ddr memory
          Mimo 7" USB Display
          XM Direct Tuner
            Alright, the setup hung up when it was detecting and installing devices. I made a new cd (it was about 10 mb heavier) and we'll see what happens. Going to look around and see if I can find any more info on the subject here in the board.
            512M ddr memory
            Mimo 7" USB Display
            XM Direct Tuner
              got streamui error, buty I just OK'd through it and it finally finished detecting devices this time.
              512M ddr memory
              Mimo 7" USB Display
              XM Direct Tuner
                Alright, got no frills windows xp running after downloading a couple of drivers. It seems to be running on about 53 mb of ram without roadrunner going (nothing else running) plus about 85 mb of disk cache going. I have 512 mb of ram, so this is nothing. I turned off virtual memory, so it seems to run pretty well like this. . .so far. I used my service pack 2 disc and installed it on the laptop I just got off ebay. I just used the key that was on the laptop (I had the disc for the laptop I got, but it had the original windows xp on it). So far so good.
                512M ddr memory
                Mimo 7" USB Display
                XM Direct Tuner
