Is there a way to disable a device when hibernate in Win7 ?
  • Is there a way to disable a device when hibernate in Win7 ?
    Hi,
    Now I succeeded to build a pc, which is also a 4 way active crossover. I use M-Audio firewire 410 as soundcard and I'm verry happy about it except, it doesn't support hibernation! If I manually disable it, then hibernate, everything works fine! I also found a program called hibernate trigger, which is used to open any program when hibernating or coming out of hibernate. All I need is a program or a script, which will disable soundcard, when executed. Also a program or a script, which will enable soundcard when executed. (A single script which enables if disabled, disables if enabled would work also!!) I use win7 and could'nt find much about this. Would anybody can help me? And I can say that I know nothing about programming and etc.
    devcon.exe
    research that
    its basically a command line device manager
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      Thanks! I researched devcon before I asked here; but I thought it was used in win xp. I installed devcon then autoit then foun some scripts to enable/disable sound card and start/kill a program.
      To hibernate I made the script to first kill audiomulch then disable soundcard (this was easy)
      For getting out of hibernate I made the script to first enable soundcard then run audiomulch; but when I do this I couldn't get sound from audiomulch. I guessed the script attemped to open audiomulch while enabling process is not completed. So I used sleep to pospone the command to open audiomulch. It didn't work either. Then I made it work by making it to first enabling the soundcard then wait 1 sec then open audiomulch, then wait 2 sec, then close audiomulch, then wait 2 sec, then open it again! Guess what? it works! I don't know why; but when getting out of hibernation audiomulch doesn't work at the first run. But I solved my problem by opening it two times! Thanks alot!!
