How to make your bt878 or other radio/tv tuner work with Radiator
  • How to make your bt878 or other radio/tv tuner work with Radiator
    I have an extremerly generic bt878 card and this worked for me. I'm sure it will work for most cards. First step is to download btwdmdrvinstaller5.3.8.zip
    from http://btwincap.sourceforge.net/download.html. This is an .exe that will run and allow you to choose your card from a list then install the drivers for that card. If your card is odd like mine it wont be in the list. If it isnt, download btspy from that same site. Install your original drivers and software, then run btspy and follow all the directions. It will create a .txt
    Then run btwdmdrvinstaller again. This time for card, choose custom. The next page will allow you to import the .txt. Then install the drivers and install radiator. All should be working. You may need to mess with some of the radiator settings, but I didn't need to. Here is some more info on btspy.
    http://btwincap.sourceforge.net/custom.html
    good luck!
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    8" Lilliput touch screen
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    Tried that already no go
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
      We have the same card though. Ill pm you my spy report. Compare it to yours. Ill make a screenshot of my radiator settings too. I'll post as soon as I get home.
      For now try this. Uninstall all drivers. Reinstall your original drivers. Make sure they work with your original software. Run btspy again. Run the .exe to install the new drivers. When this happens, windows will say, "found new hardware." Click cancel. It will ask again. Click cancel again. Restart your computer. It will say found new hardware again. Cancel twice, just as before. Then go into hardware manager and disable the 2 items that have the yellow question marks. I'll make a screen shot of this as well. Try this and let me know. Good luck.
      2.4 celeron
      150 watt OPUS
      micro atx
      xp pro
      tv/radio tuner card
      audigy
      Dual monitor Radeon
      802.11G Mimo
      xm pcr
      dvd
      gps
      IGuidance
      dual optimas
      battery isolator
      15" screen
      My Truck
        http://s88024846.onlinehome.us/tv/
        my BT spy report is on there.
          Does your chip say BT878a?
          Conexant Fusion?
            I saw yours but I'm at work so I dont have access to mine at the moment. Pluse we know that mine works. So you can try to create the drivers using my profile. Post a pic of your hardware manager with the sounds column expanded. I'll see if it looks like mine.
            2.4 celeron
            150 watt OPUS
            micro atx
            xp pro
            tv/radio tuner card
            audigy
            Dual monitor Radeon
            802.11G Mimo
            xm pcr
            dvd
            gps
            IGuidance
            dual optimas
            battery isolator
            15" screen
            My Truck
              Here is the screen shot of radiator settings.
              2.4 celeron
              150 watt OPUS
              micro atx
              xp pro
              tv/radio tuner card
              audigy
              Dual monitor Radeon
              802.11G Mimo
              xm pcr
              dvd
              gps
              IGuidance
              dual optimas
              battery isolator
              15" screen
              My Truck
                Hardaware manager. The 2 with the question marks i had to disable to prevent windows from trying to install new drivers everytime i turned on the computer.
                2.4 celeron
                150 watt OPUS
                micro atx
                xp pro
                tv/radio tuner card
                audigy
                Dual monitor Radeon
                802.11G Mimo
                xm pcr
                dvd
                gps
                IGuidance
                dual optimas
                battery isolator
                15" screen
                My Truck
                  and card profile. This is the profile for the SuperTv tuner. It most likely will not work with others so dont try, unless thats the card you have.
                  2.4 celeron
                  150 watt OPUS
                  micro atx
                  xp pro
                  tv/radio tuner card
                  audigy
                  Dual monitor Radeon
                  802.11G Mimo
                  xm pcr
                  dvd
                  gps
                  IGuidance
                  dual optimas
                  battery isolator
                  15" screen
                  My Truck
                    This is fantastic. After removing the original Hauppage drivers, and installing those, fantastic, my copy of Radiator now works, without the XP issue that the Radiator message boards mention.
                    4x4 in a turbo stylee.
                      all I get now is just static, I get an error in the 8x8 dll when I try to use the scan buttons.
                      What is the Xp issue?
                        you need to use the 8x8wdm dll not the 8x8 dll.
                        It has been discussed on the guest book/message board over at www.flesko.cz.
                        It appears that WinTV cards, and XP need the user logged in as administrator (not just an administrator level user) to work, even then sometimes it doesn't fix the problem.
                          I am using the plugin 8x8wdm dll, I didnt remember the name when I type the post, also, I cant get any External Properties for that DLL, I press the button and get nothing.
                          Bah! this sux.
                            I had that happen a couple times too. I just kept clicking configure and restarting radiator, and eventually it worked. Try reinstalling radiator. Make sure when you uninstall your deleting the folder from program files as well. That way you delete any old settings as well.
                            2.4 celeron
                            150 watt OPUS
                            micro atx
                            xp pro
                            tv/radio tuner card
                            audigy
                            Dual monitor Radeon
                            802.11G Mimo
                            xm pcr
                            dvd
                            gps
                            IGuidance
                            dual optimas
                            battery isolator
                            15" screen
                            My Truck
                              Glad to have helped!
                              2.4 celeron
                              150 watt OPUS
                              micro atx
                              xp pro
                              tv/radio tuner card
                              audigy
                              Dual monitor Radeon
                              802.11G Mimo
                              xm pcr
                              dvd
                              gps
                              IGuidance
                              dual optimas
                              battery isolator
                              15" screen
                              My Truck
