New FM radio Plugin for all engines !
  • New FM radio Plugin for all engines !
    better then the old Radiator because:
    1.surport record to MP3 or record to MP4
    2.surport TIME SHIFT function, you will not miss any song which you like
    just record it through the star gate...
    3.Forgot to say the BEST advantage: start FAST, within 1 second !
    exe file larger than 2M
    http://www.carpcs.net/dragonbtv/FMpl...lugin10151.zip
    anyone who downloaded the Beta MUST give feedback here!
    here is the screen snap
    have ADD and EDIT functions
    easy to add stations and edit them
    stations.txt looks like this:
    097.4,Beijing Music Radio
    103.9,Beijing Trafic FM
      And this works with ?
      [H]4 Life
      I'm a lesbian too.
      I am for hire!
        prestrathed for 800x480
        works fine with 800x600
        not skinable up to now
          fully tested with your frodoplayer 1.09
            I mean radios.
            [H]4 Life
            I'm a lesbian too.
            I am for hire!
              Axife FM Player Delux 2.35 and above
              just used it's FMengine.exe alone, not a skin of it
              this plugin does NOT surport skin right now....
                What language did you code this in?
                PowerVoice v1 | NaviVoice Source
                GammaControl v2.4
                SKINbedder v3
                1995 Lexus SC300
                  delphi ---> PASCAL
                    delphi ---> PASCAL
                    I like you I also write in delphi (7). What components did you use for this?
                    GammaControl v2.4
                    SKINbedder v3
                    1995 Lexus SC300
                      the only special is Xibutton
                        Radiator need a lot time to start to work with Frodoplayer...
                          Wow! This is advanced I'm guessing then that you used DirectShow
                          GammaControl v2.4
                          SKINbedder v3
                          1995 Lexus SC300
                            the equalizer vitral display is based on winamp dlls
                            here is another picture. meter color and looks changed, looks better I think.
                              Is it available for download? (same question for TV plugin)?
