skin the zoom bar?
  • skin the zoom bar?
    how do you change the graphics for the zoom bar?
    Ive seen some skins that have changed it, but i dont see where the graphic for the zoom bar is located at in FD dir. or the destinator dir.
    Ditto for the pop up menu too.
    also, is there a command/button toggle that makes the map go fullscreen and back?
    thanks
    01101100 01101001 01110001 01110101 01101001 01100100 01011111 01110011
    01101101 01101111 01101011 01100101
    beer replenishment fund
    http://www.mp3car.com/vbulletin/forumdisplay.php?f=93
    mp3car live search
    i have joost invites, just hit me up for one.
    popup menu isnt skinable yet, altho you can capture the FD "menu" event and have a road runner menu appear...
    I dont remember where the zoombar one is, but I think it is somewhere in the destinator stuff... one of the large images which contain several graphics
    Roy
    2005 Range Rover 4.4
      cool, i wont worry about the zoom bar for now, ill try to find the graphic
      but how do you capture the event? Or do i have to make a menu button, i kind of like it that the menu pops up when you click the map or must i do it the other way?
      mp3car live search
        you n00b!
        j/k
        here ya go...
        Originally posted by CDRSkull
        not in FreeDrive its not, but it is in RoadRunner. Let me explain.
        1. In the SDK.ini file in the freedrive folder add FDMENU=RoadRunner
        2. Create a skin in RR called FDMENU.SKIN, also create sub menus if needed
        When you add FDMENU=RoadRunner in the SDK.ini file, this tells freedrive that you want all menu presses (includes touchmenu) to tell roadrunner to show its menu screen. The FDMENU.SKIN would be a menu skin.. a bit like the exit skin which would auto center on the screen and also allow you to have whatever you want anywhere. Then in the FDMENU.SKIN.. say you wanted a address button you would have something like...
        B,0,380,80,130,"SendMsg;FreeDrive;Address||EXIT",
        This would then send the sdk command to FD to display the address box and also close the FDMENU.SKIN to return back to normal. You could if you wish have a FDMENU2.SKIN so you can have more options, even have a 'next' / 'prev' button like on the FD menu which toggles back and forth between FDMENU and FDMENU1.
        so say you want another menu.. so you can have more stuff on , you would use something like
        B,0,380,80,130,"EXIT||MENU;FDMENU1.SKIN",
        Think that would work.. it would close the current menu and open the FDMENU1.SKIN
        hope this makes sense.. I have tried to include lots of sdk commands to make skinning the menus from RR easy
        cheers
        CdR
        FreeDrive current version 0.80 Full Website
        Ford ST220 install -> Stage 2 Fabrication
        IRC Chatroom #mp3car Server chat.webmaster.com
        or connect via java by clicking HERE
        Roy
          cool, thats exactly what i need.
          THANKS
          mp3car live search
            To change the zoombars you have to edit this file:
            C:\DestinatorApps\Destinator\Common\Interface\Visu al\All\destinator.bmp
            It takes some trial and error to make it the right size though.
