freedrive is crashing
  • freedrive is crashing
    Hello there,
    My car PC is almost ready for navigation. I've got freedrive embedded is RR en it's great. The only thing that drives me crazy is that it crashes every time it calculates the route.
    I've got the updated .exe fil in the freedrive folder.
    The old freedrive always worked perfect in my old setup.
    Plz help!
    CDRSKULL: It would be great if you inplent the ability to use keystrokes in freedrive or through road runner. because i use an remote control.
    Thanks in advanced
    FreeDrive has an SDK. You can use that to control it from RR. Thats what I do.
    The road is long but we are getting there.
      @ Toslin : could you post here your soluce to command FD via SDK ? Thanks
      @Bobcoupe : I agree with you it could be great to have keymap as in RR
      Try FDKEY : http://www.freedrive.co.uk/forums/sh...9&postcount=10
      With it i can almost use freedrive with a Powermate.
      For crashes wrong map ? Or try desinstall reinstall Freedrive ?
        Thanks alot grave!! This really helped me out!
        The only problem now is that i need a way to jump from RR to FD because when freedrive gets focus i can't adjust the volume in RR anymore.
          In FD Key, you can send the mouse cursor in a special area.
          I use Esc to click the return button in RR
          (and i also use my wheeldrive buttons to ajust volume )
            Here is my external_gps skin file for controllinf FD from RR
            MEDIACAR Skin
            MEDIACAR F-CNS(800x600Stretched)"ExternalGPS" Skin
            external_gps_off.jpg,external_gps_off.jpg,external _gps_off.jpg,external_gps_down.jpg
            /, IDL, Seconds
            IDL,180
            /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
            L1,13,13,66,24,0,255,0,15,"MgDigital","=SATS","cen ter"
            L2,8,34,76,33,255,255,255,24,"MgDigital:B","CUSTOM FDSATS","center"
            L3,23,70,47,24,0,255,0,15,"MgDigital","=DIST","cen ter"
            L4,7,94,77,33,255,255,255,14,"MgDigital","CUSTOMFD DIST","center"
            L5,7,123,77,33,255,255,255,16,"MgDigital:B","CUSTO MFDHEAD","center"
            /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
            B01,2,162,86,74,"SENDMSG;FreeDrive;home",""
            B02,2,240,86,74,"CLOSEWINDOW;FS_NO||SENDMSG;FreeDr ive;address",""
            B03,2,322,86,74,"SENDMSG;FreeDrive;clear",""
            B04,2,401,86,74,"SENDMSG;FreeDrive;favorites",""
            B05,751,3,86,62,"SENDMSG;FreeDrive;ZOOM:-50",""
            B06,751,70,86,63,"SENDMSG;FreeDrive;ZOOM:+50",""
            B07,751,137,86,63,"LOAD;external_gps_max.skin;;;Fr eeDrive||RUNQ;c:\program files\roadrunner\fs\fs_yes.exe",""
            B08,751,204,85,67,"CLOSEWINDOW;FS_NO||MENU;FDMENU. SKIN","exit"
            B09,751,274,86,63,"SENDMSG;FreeDrive;GPSconnect",
            B10,751,341,86,66,"RND||RND||STOP||NEXT||PLAY","Ne xt/FF"
            B11,750,412,88,64,"CLOSEWINDOW;FS_NO||EXIT","exit"
            /, A, x, y, w, h, color R;RGB, G, B
            A01,92,8,655,461,255
            END
