Important rtequest for EzSync
  • Important rtequest for EzSync
    Can you please add the option to CLOSE the utility after it has been opened, and after sync?
    Something like this:
    1) App opens
    2) Attempts to sync
    3) If IP found, 6 pings, syncs and CLOSES the application
    4) If IP not found etc. it CLOSES the application.
    This way, it would be very easy for us to create scripts that run this util before hibernation (by simply launching ezsync before hibernation), and easily determine when hibernation can occur (i.e., wait until EZsync has closed before continuing with the script and hibernating etc.)
    RIght now, there is really no way for us to script something that would force/attempt an EZsync, and determine when it has finished syncing (or finished 'trying').
    I say it would be a nice option, because most people might just want to leave it open all the time etc...
    EDIT: This is the reason why I am wanting this so badly!
    http://www.mp3car.com/vbulletin/show...3&page=1&pp=15
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
    Ric355, are you alive?
    What's status on development of new version?
    2002 Honda CR-V
      1) App opens
      2) Attempts to sync
      Better still would be the option to shutdown/suspend/hibernate after sync..
      Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
      Status -->
      Lilliput Installed (not indash yet..)
      BraveCar 2.5
        Better yet, an option to run a program/script after sync. Then we can do whatever we want
        2002 Honda CR-V
          mutch better, yes
          Status -->
          BraveCar 2.5
            Yes, I'm here.
            Development is finished except for one problem I've got to iron out. I've been working on a new web site which needs to be finished before I can launch it.
            Bravellir the option to shutdown after sync is in the forthcoming release.
            With regard to the original request - I think you're really looking for something that will initiate a sync, wait until it completes, and then return, so that you can incorporate it into a script. This shouldn't need EZSync to close. EZSync is meant to be running all the time and I'm not going to change that concept. One question I have though - don't you have a time limit on the Opus like there is on the Carnetix? i.e. when the Carnetix sends a signal to the power button to get the PC to shutdown, it starts a timer which, once it expires, power is disconnected from the PC. If this is the same on an Opus then you could find the power getting pulled before you've shut down or even finished syncing.
            EZSync - http://www.richmet.com/ezsync
              Originally posted by ric355
              Yes, I'm here.
              Well, I am looking for a way to detect when the sync has completed. If EZsync closes after completion, that is an easy way to detect completion
              You say you are adding support for shutdown after sync; would you consider adding an option for Hibernation after sync too? If that is implemented, there is no longer a need to 'detect' sync completion, because the reason I was trying to detect such state was to initiate a hibernation command afterwards.
              Note: better yet, I would love to see option to run a program/script after sync completes. Full flexibility and power to the user!
              That's a good question. I think this can easily be bypassed anyway by setting the Opus to shutdown in 60 mins instead of 10 secs. We would be sending a hibernate/shutdown command after sync completes anyways, so 60 mins would never really be reached.
              2002 Honda CR-V
                See post #7 in this thread: http://www.mp3car.com/vbulletin/showthread.php?t=54435
                I could be wrong on this, but if you send a hibernate command to the PC from software, it may not cause your power supply to shut off. Hence your supply might remain active powering everything else (eg screen) for the full 60 minutes or whatever the setting is. See post #2 in the same thread. This could flatten your car battery.
                All I'm saying is be careful - hibernate / shutdown / sleep functionality is already implemented but you need to be aware of the power related issues surrounding it.
                  ric355, I'm the one who requested the "hibernate/suspend after completion" feature. I'd second justintime. If you could add the ability to run a script/exe after synching is done (ie, after EZSync detects a change and launches the syncing process), that would be great. This way, we users are totally responsible for any power related issues.
                  I myself use a laptop so power is not a concern for me. My laptop can run a full 2 hours without power.
                  The way this would work is that EZSync still runs silently in the background and applies changes automatically. The user doesn't need to initiate anything. The only difference is it would run a script after a change in the file structure has been detected and synced up. This way it will be our problem if the script we write screws things up (like incorrectly shutting down the PC as we drive off the driveway).
                  iGMon - Integration between iGuidance and Road Runner
                  CFX - Skin for Road Runner
                    ALl I really want is a way to allow this to happen:
                    1) I switch my car off
                    2) Ezsync immediatley launches (or maybe its already launched) and attempts to sync
                    3) It completes sync process (whether there are files to sync or not is irrelevant)
                    4) PC hibernates/shutdown etc.
                    I dont think this will be possible with new version, based on what I read!
                    2002 Honda CR-V
                      I donít think this will be possible with new version, based on what I read!
                      To achieve this you would have to set your opus to shutdown after 60 minutes?
                      I didn't realise this before. This would mean that every time I turn off the car, the Carputer would take 60 minutes to shut off.
                      Don't think its a good idea. What we would need was some kind of way to bypass the ignition wire.
                      Some kind of circuit that when Ezsync detects a server, it would switch the ignition wire to the 12v wire and that would switch back when finished...
                      serial or paralel port
                      ! -----------DC/DC
                      relay
                      ! !-----------ignition
                      12v
                      Just an idea...
                      Status -->
                      BraveCar 2.5
                        Bravellir:
                        No, no... all you really need is for EZSync to initiate a Shutdown at the end of the sync process.
                        2002 Honda CR-V
                          Bravellir:
                          How?? My M1-atx shuts down the carputer a few seconds after I take the keys off the ignition. And thats the way I want it to be 99% of the time.
                          Status -->
                          BraveCar 2.5
                            I kind of mentioned it above... there is a new tool that lets you intercept a shutdown sequence, and put a script in its place:
                            (See post #42 for the actual app)
                            2002 Honda CR-V
                              Tks.. missed that one. I'm going to try it..
                              Status -->
                              BraveCar 2.5
