only one folder sync
  • only one folder sync
    Hello I have ver 1.92 and I have 3 folders that I sync with my car, but it will only sync the first folder in the list and not the 2 other.
    what do i do wrong...
    I think there is probably an error happening during or at the end of the sync of the first directory. If this happens it stops syncing.
    Unfortunately it is difficult for me to identify the cause.
    Post up your server side .ini file; that may give a clue.
    EZSync - http://www.richmet.com/ezsync
      [Config]
      Port=4000
      InitialDir=C:\Program Files\ezsync\
      TempInputFile=C:\Program Files\ezsync\tempin.dat
      StartMinimized=0
      ExtraUpgradeFilesInstalled=1
      ClientInstallDrive=C:
      [Directories]
      D:\Til CarPC=C:\Upload,C,*.*
      D:\Kate=C:\Musikk\Kate,C,*.mp3
      D:\Musikk=C:\Musikk,C,*.*
        just wanted to say i have this same problem. Any clue how to fix it?
        Live mp3Car Facebook Chat
          It is hard to tell what the fault is - I think the program must be failing internally during the sync, and so it quits syncing before any more directories are done. This is the only way I've seen this occur during development - unfortunately therefore no workaround. You could try changing the directory structure or altering the filespecs used for syncing to see if the problem goes away.
          Ric.
            [Config]
            Port=4000
            StartMinimized=0
            [Directories]
            For ClientInstallDrive= Are we suppose to be a mapped network drive or the local drive of the client?
            PROGRESS 95%[//////////]Complete - Software configurations
            Current Task: Just adding on...
            Needed:wireless keyboard/mouse
            My Carputer Blog
            Car System Site
              Can you synch files from an external drive?
              My Carputer Blog
              Car System Site
                Ok, I figured this out. The target drive has to be a local drive to the carpc. Don't use the network mapped drive.
                My Carputer Blog
                Car System Site
