PCMCIA WiFi vs. USB WiFi
  • PCMCIA WiFi vs. USB WiFi
    Is it pretty safe to say if using PCMCIA WiFi is most likely to connect to an access point than say an USB WiFi mounted at the rear window?
    At the moment, I have a TabletPC mounted under the center console (Nissan Altima 2005) under the AC dials. Using a Cisco Aironet 350 B wireless, and it picks up a few open access points no problem. I was just curious to know what if I had an external USB unit like this - Linksys WUSB54GP:
    http://www.linksys.com/servlet/Satel...=2762239789B47
    Currently I have an USB hub mounted under the trunk, I have hooked up the Microsoft GPS, wireless keyboard receiver and maybe this USB WiFi device if it's better.
    Or any other suggestions would be much appreciated.
    No. There are too many factors to even attempt a blanket statement like that.
    Perhaps a high-power WiFi device is the ticket? Search for SENAO on these forums. Several of us use this adapter and are very happy with it. It's far more powerful than a crappy USB wifi dongle and most PCMCIA wifi cards.
    How about the Wiki?
      I think you may want to search for Senao or Engenius. Here is something to get you started.
        D'oh!
        Pardon my typo (now corrected).
        How about the Wiki?
          Thank you guys for the link, I'm going to see if I can get one from Canada, but the price is pretty good. Do you think it will work with USB 1.1, or I need USB 2.0 to work? I don't mind the "B" performance but trying to avoid adding an USB 2 PCMCIA card to the Tablet if possible.
          Thanks again.
            I wouldn't use any USB wifi adapter on USB1.1.
            How about the Wiki?
              why not? If you are using b, and also transfering files through the internet, and not just an intranet, you will never realize the full speed of 2.0 anyways...
              Under ideal situations, you could, but realistically, I dont think it will happen
              1.9in x 2.9in -- 47mm x 73mm
                Okay, any suggestions as far as which PCMCIA USB 2 card to get, and a 4-port USB 2 hub as well?
                So far I have tried Adaptec USB 2 PCMCIA card, along with 2 USB 2 hubs, anything that I plugged into the hub didn't get recognized. If I used an USB 1.1 hub, everything worked okay.
                I may try another USB 2.0 PCMCIA card but so far the USB 2 experience hasn't been so good.
                Just to add, I only have 2 USB devices - MS GPS and Gyration wireless keyboard.
                  Alright, one more question! So far I've planned to get the following to work:
                  a) Gyration wireless keyboard
                  b) MS GPS
                  c) Bluetooth
                  d) Wireless b/g adapter
                  Tablet comes with one USB 1.1 port, a PCMCIA slot for a potential USB 2 card. If I use the PCMCIA card, I will still need a hub as most USB 2 cards have only 2 ports. Ultimately I want to plug everything to the hub and the hub will be hiding in the trunk. Would I be able to plug everyting into a hub and just one cable to the PCMCIA 2 card.
                  I guess in this case, the hub should be powered?
                  Thanks again for your help.
                    You're correct. I look at USB1.1 as a potential bottleneck. Whether it will be in real-world situations or not, I want to prevent that bottleneck.
                    I've had broadband for too long. I guess I'm spoiled.
                    b) MS GPS
                    c) Bluetooth
                    Yeah. A powered hub.
                    The GPS can go into USB1.1. The data flow is far slower than even USB1.1 (4800bps).
                    How about the Wiki?
                      USB all the way... I mounted mine inside my homemade antenna. It's working very well so far.
                        I'd just like to chime in and say that I had really good luck with my old Buffalo PCMCIA wifi card and a $10 external antenna that i found on eBay. I really don't like USB wireless cards, as far as I'm concerned wireless throughput is bad enough without trying to use the USB bus for networking as well. Also, I'm not convinced that the range is good enough. Sure, some will say that you can hack your USB adapter to wire up a huge antenna, but why void your warranty when there are other combinations that are proven to work.
                        http://www.buffalotech.com/products/...ebook-adapter/
                        http://cgi.ebay.ca/ws/eBayISAPI.dll?...MEWA:IT&ih=009
                          It doesn't matter, it depends on the transmit power and receive sensitivity of the radio not the form factor... I think the Engenius USB adapter has the best balance of power and sensitivity.
                          Whatever you choose if you want distance then an antenna port is a must.
