Anyone add a wifi antenna to their Mac mini?
  • Anyone add a wifi antenna to their Mac mini?
    If so how any write ups on this? I searched and found nothing. I know where the antenna is in the case but don't know how hard it would be to upgrade the antenna. Any help is appreciated <br /><br />
    As you sow, so shall you reep
    My Install- http://www.mp3car.com/vbulletin/show...-10-4-lcd.html
    Im not familia with macs, but I know a worklog thread that is. Here is a link to the specific wifi post within it.
    Continued Worklog... Upgrades in progress:
    *15.4" WXGA LED backlight touchscreen upgrade
    *Custom fiberglass dash bezel
      thanks that was somewhat helpful, but I would still like to see what some on did with their mac mini.
        The hardest part is going to be where do you put the antennas? You're going to need at least two, if it's 802.11n you'll need three. You'll need ufl to r-sma or r-tnc pigtails.
        Failure is not an option....
        It's installed by default on every version of Windows.
          I'm not so worried about the antenna's as I am connecting them to the computer. I was wondering if mybe there is some USB antenna or USB wifi w/ a antenna hook-up. I'm suprised more people aren't asking questions about this topic.
            Whats the difference between dbm and dbi? I found this one on ebay I think I could put it in my back window, but is it worth the money?http://cgi.ebay.com/1-2Mile-Booster-...QQcmdZViewItem
              Damn nice antenna. The only problem with that one is its really directional. Your only going to get WiFi behind you while you drive. I guess it would be okay if a friend of yours is driving behind you with a WiFi antenna pointing forward. Then you could have lan games while you drive what you need is omni directional like this ebay antenna.
              http://cgi.ebay.com/19dBi-Omni-Direc...QQcmdZViewItem
              Not as much db that the other one had but 19db is still pretty good for omni directional antennas.
              Um, I guess this is where you put something witty.WITTY
              My Web site, in the design stage. http://home.comcast.net/~cstrachn
              Modified RRSkinEditor http://www.mp3car.com/vbulletin/showthread.php?t=65723
                I wouldn't buy that antenna. It's only a 10 degree beam width. What ever you wanted to connect to would have to be pretty much at the same elevation as the antenna. That thing also has a N connector on the end of it. Look at the picture again, N connectors are about a half inch in diameter, that antenna is about 3 feet long.
                As far as connecting an external usb adapter, as long as it's mac compatable, (if you're still running os x on it) it should work just fine. I'm pretty sure there have been some folks running them that way here on the boards.
                  10 degrees vertical and 360 horizontal. If it sticks out your roof or what not 10 degrees vertical is more then enough for level areas. Maybe if your driving through the mountains searching for WiFi. 3 foot antenna would be great. I saw someone driving down the street with a huge as pipe antenna looking thing. about 5 feet from the tail gate to the roof of an suv.
                    under the specifics it says Dimensions 11.5x4.8x1 (inch) Thats not 3 feet long it almost a foot long. But thanks for your info. I'm not going to buy that antenna now.
                      I was talking about the 19Dbi omni, which is 90cm long, or in english 2.95 feet long. Also you asked about adding antennas to a mini, not a usb radio/antenna to it. Completely different beast.
                      So, what do you want in an antenna? If we knew what your objective was, we could steer you in the right direction.
                        sorry If I was unclear but I don't know alot about wifi. I basically just want to pickup more wifi spots where my mac mini is located it doesn't get a very good signal. I did find this http://www.quickertek.com/products/Quicky.php High price but would it work?
                          Yea, I have a bridge I want to sell you too. Check this post out.
                          http://discussions.apple.com/mailpos...sageID=4869460
                          I have a Belkin f5d7050 that I picked up at home depot a couple years ago that also has a ralink chipset that works as well.
                            I found that quickertek item on ebay and won it. I paid a little less than a hundred for it shipped not to bad considering it cost 225. plus shipping from the website. I'll let you know how happy I am with it
                              Still think you paid too much for it. You can buy usb wifi adapters in the $50 or less range.
