Centrafuse and bluetooth
  • Centrafuse and bluetooth
    I have Centrafuse 1.1 I could not get bluetotth working
    PhoneControl.NET always makes error.
    I downloaded CF 1.2, the result is the same.
    what is wrong? and what can I do?
    Your ****tin me right? Noone can help based off that description.
    What errors are you getting? What stage are you having the problems at? Can you get the devices paired?
    You know Centrafuse is now at 2.0 with a new bluetooth stack too.
      Phonectl.NET.exe has encountered a problem and needs to close.
      that's the error
      out side of Centrafuse , my P990i is connected to the blue tooth USB.
      when configuring phone , centrafuse calls PhoneControl.NET PhoneCtlWizard
      when just pressing finish and only when bluetooth is enabled in centrafuse that error appears.
      I hope I could cexplain the problem.
        that's the error
        I had this problem when I had .net 2.0 and .net 3.0 installed on my pc. I uninstalled .net 2.0, .net 3.0 and .net 1.1 and reinstalled .net 1.1 and phone control no longer crashed on startup.
          UM, just update CF to a higher version, your using such an old instant of it. PhonCo isnt even alive anymore, its been killed by the creator. CF now uses a new bluetooth stack which seems to be way better and works with alot more phones. Only issue is CF RC 1,2,3 dont have full licensing for the BT stack, so there is a 5 mb limit of use.
          1X Ainol Novo Flame Tab
          4X MK808b
          3x Perixx Touchpads
          3x 7 inch Screens
          1X 7 inch motorized Screen
          1x Win 7 PC
