{Solved} Gps Reciever Problems
  • {Solved} Gps Reciever Problems
    I have a BU-353 GPS reciever that i bought from mp3car. It has always worked fine but i recently started having problems. When i use the GPSInfo program and the output is all messed up. It looks like *~:
    ///n*2 AӴ~: insted of the normal numbers. I have updated the drivers and checked the baud rate. I am running out of ideas. Any suggestions?
    I used a program called sirfdemo.exe to change the settings of the receiver. It was complicated and im not really sure what i did. I also read that with this receiver you can unplug it for 48 hours and do a factory reset. I was impatient and looked for other solutions.
