Need to figure out the correct adapters/connectors for these devices
  • Need to figure out the correct adapters/connectors for these devices
    Hi I am going to purchase these 3 devices as soon as I get confirmation on the correct connectors I need to get for them so I can order the length of cables I need from fab-corp.The first device I need to know what connectors it sports at the rear is the Linksys-Cisco WRT54GL Wireless-G Broadband Router can be found here
    http://www.amazon.com/gp/product/B00...pf_rd_i=507846
    I would like to remove the external antenna it has and connect a short pigtail with correct Coax cable connectors/adapters from it into this device >>>>>Hawking HiGain Signal Booster version 2 - HSB2 which can be found here
    http://www.amazon.com/Hawking-HiGain...1688355&sr=8-1
    And at the other side of this hawkings device I would like to remove there little antenna and use a larger omni-directional antenna.The omni antenna I am planning to use is a 2.4 Ghz Omni-directional 15 dbi Antenna from wi-fi link which can be found here http://www.amazon.com/exec/obidos/tg...GVWN2&v=glance
    I would like to connect these 3 devices to each other....So again all I need is to know is which adapters and connector types,please specify male and female that I would need to get to connect them successfully.....I would like it in the order starting with the linksys router all the way tru up to the Large Omni-Antenna which I think has a N female connector on it..if I am right....This information is critical to my first wireless network and would like it to be presented in the best simplest form...thank you.
