Help! Blue Soleil on Win 7
  • Help! Blue Soleil on Win 7
    I can't seem to get Blue Soleil working on my Win 7 system.
    It appears that the windows Bluetooth stack doesn't get de-activated after I install BS.
    I have 2 bluetooth icons in the system tray and can't pair with anything.
    I remove BS and the windows stack works fine, and can pair with devices.
    I ran the hardware test application from BS and it says that my dongle is compatible.
    Anyone run into this?
    TruckPC - gutted, being used for test setup
    BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
    BlazerPC - Nexus 7 with Timur's USBROM
    All I had to do was install it and it worked fine for me on Win7. You may need to go to device manager, update driver on your bluetooth device to use the new bluesoleil driver you installed.
    EWF, HORM, MinLogon on XP.
    Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
    Win Embedded Std 2011 RC
    OCZ Vertex Turbo 30GB SSD
    Lilliput 629 Transflective, WRX Screen Mount
    BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
    VoomPC 2
      What type of system do you have. i mean did your system come with a bluetooth adapter is it built in. Because I was running win7 on my system and had no problems either setting it up. if you already had a adapter and there are 2 bluetooth icons that's what that means you may have to uninstall the built in one to get the bluesoliel to work correctly.
        Not built in, its a Rocketfish USB bluetooth adapter.
        I think that its not compatible with BS, even though their hardware verification tool says that it is.
        I try uninstalling the standard Win7 drivers, and install BS, however on reboot the standard Win7 drivers automatically re-install.
