Connecting two phone over bluetooth. I there possible?
  • Connecting two phone over bluetooth. I there possible?
    Does anybody had succesed to connect two phone (headset connection) to the car pc on the same time.
    For example if I have two different phone (one on one GSM network and the other on other network) is there any posibility to make the computer (eg. CarPc) to act as multi-point headset or something similar to be able to receive cals from the two phones,ok not in the same time, but to able to answer from the same pc for example. To not every time change the default connection.
    Does you know about some tricks to do this thing.
    I've search on the internet and the only thing found is only some headsets that are capable to do that but for PC software I've get nothing.
    Cheers!
    Renault Megane II Eeepc install.
    theres half a dozen threads with the exact same question
    openMobile - An open source C# Front End (why choose openMobile?)
    - Always Recruiting Developers -
    Like what you see? Donations are always welcome
      http://www.lmgtfy.com/?q=pair+two+cell+phone+bluetooth
      The first result at ehow.
        Ok
        Thanks for reading and reply but this is not my question.
        I had "pair" the both phone with the car pc but only one is working all the time, the other phone is working if i disconnect the "first" one.
        I was asking if is possible to make both working without disconnecting the first phone connected.
        For example:
        Connect "phone no.1" to carpc,
        Connect "phone no. 2" to carpc,
        Receve calls on the phones and automatic answer the phone who is ringing. For eg. "phone no 1" calling and push answer and "talk". "Phone no 2" ringing, push answer and talk, "phone no 1" ringing again and push talk and answer.....and so on, no mater what phone is ringing. Without being necessary to disconnect one phone and talk on the other one, because now is working only if I disconnect one of the phone is ringing on the other one.
        Please show me the treads were is explain because I did not find something like that to be able to to what I need.
        I've found only device (head sets with multipairing ) that are capable to do that, but I thing is much more nicer to be able to use carpc and not having to wear all the time a headset.
        Respects!
          nobody know?
          Please help.
          Cheers!
            Try Google Voice and have your phones auto disconnect.
            Andrew
              thanks man,
              but something else I can't find? Because is just for US only and it also require internet connection, for all time for calls, plus that it require invite.
              I'm thinking for something more easy. is there any trick to full the PC to connect to both phone in the same time and to pick calls when they arrive.
              Cheers!
                Currently....no
                  Your next question should be "will windows support 2 BT USB dongles and allow them to coexist in windows?"
                  If the answer is yes, you may be onto something then. I have no clue if it will work, but maybe somebody has tried it.
                    Actually the answer is yes, I tried this once, had my phone paired to the PC with one dongle, and my headset paired to the other and was able to hear and talk through the headset to the pc to the phone, I did this for kicks, and to prove to a friend it could be done. Now the question I have is what software is there that will communicate with two dongles simultaneously and allow the interaction your looking for.
                    Now on the other hand my bluetooth device in my CarPc supports up to 8 simultaneous connections at once, but then again the software issue comes up.
                    Can't think of a single cool thing to type here........
                    Progress:
                    Hardware:
                    Parts Acquired: 90%
                    Configured: 50%
                    Software: Not Even close!!!! Looking for a good phone software solution
                    Fabrication and Install
                    Screen Mounting Figured Out!
                      very strange that nobody had think about that, because (at least in my area, i don't know you) everybody have 2 phones. One from company and one personal, or if not that one from vodafone and the other orange, or orange-cosmote or vodafone-cosmote, mostly one of it pre-paid.
                      I just have to wait then, and pray that someone it will make-it possible. I'm thinking now at somebody like centrafuse or streetdeck or also guy developing road-runner and the others front ends.
                      If some of you discover that this option appear please inform me also (just in case i'll not discover it)
                      Respect to all, and please make it possible!
                      Cheers!
