No Outgoing Audio from Centrafuse 3.0 Phone
  • No Outgoing Audio from Centrafuse 3.0 Phone
    To start I am a IT Tech of 13+ years and am very computer literate, owning my own PC Business for the last 2 years......
    I have recently installed the latest version of bluesoleil 8.0. I am running Centrafuse 3.0 on the bellow system:
    Windows 7x86 (32bit)
    JetWay JNC94FL-510-LF Intel Atom D510 BGA559 Intel NM10 Mini DTX Motherboard/CPU Combo
    OCZ Vertex Series OCZSSD2-1VTX60G 2.5" 60GB SATA II MLC Internal Solid State Drive (SSD)
    ENCORE ENMAB-8CM 7.1 Channel USB Audio Box
    OCZ Gold 800MHz Duel Chanel memory 4GB
    M3-ATX PSU
    Rocketfish™ - Bluetooth USB Adapter
    Model: RF-FLBTAD
    The problem i am having is:
    1. The incoming (other person) audio when paired with my phone is poor, kinda garbled
    2.The person on the other end of the call can't hear me. My mic is functioning in both vNotes and windows Sound Recorder
    3. I don't know if this matters or not but there is a headphone icon in Centrafuse, and i have heard that is suppose to be a computer icon....?
    The BT adapter that i am currently using is the second one i have tried, with the exact results which tells me it is not a driver, or BT hardware problem. Also, my Motorola Droid is "rooted" (jailbroken) running a 2.2.1 ROM. I do not believe this is the problem as i have restored the phone back to factory settings with the same problem. I have also tried a combination of options for pairing from the phone all with the same result....no outgoing audio from me to the other person.
    Steps I have taken to try to solve the problem are as follows:
    1. Updated Motherboard (chipset) drivers
    2. Updated Audio Drivers
    3. Updated USB audio card drivers
    4. Used both onboard and usb mic
    5. Rolled back the above to previous driver versions
    6. Paired and unpaired both devices and repaired them using both PC and Phone to initiate the pairing
    7. Uninstalled CF 3.0 and Bluesoleil 8.0 and reinstalled with a registry clean and reboots in between
    For those of you that are wondering, the version of Bluesoleil 6.xxx that came with CF 3.0 would do the exact same thing, except the incoming audio was even worse.
    If anyone has any ideas on something else i could try please let me know because i feel that i have exhausted all my options. my only hope is that CF 3.5 will solve these issues for me and others with similar issues. Thank you in advance for everyone's help and support!
    Expert IT Administrator/Technician
    A+, Net+, Sec+, MCP, CEH
    M3-ATX PSU
    Model: RF-FLBTAD
    First to clarify, are you running CF3.0 or CF3.1? If it's 3.0, you need to upgrade to 3.1.
    I have a DroidX (rooted), Realtek on-board audio and BS 8.x and everything works okay for me. Sound quality (outbound) remains a problem as I try to find a mic that really works well in the car, but incoming sound is pretty good. I have run this setup on CF3.1 (and currently on CF3.2/5) and with the exception of outbound sound, it is pretty solid.
    VegasGuy
      VegasGuy
      Correction its CF 3.1. let me know if you ever solve the outbound sound problem. im just using a cheap $10 logitech mic from wal-mart ATM. it works great for everything else but CF......my co-worker has a Droid X rooted and im going to test it with his to see if its my phone.
