Antenna for Router
  • Antenna for Router
    I want to add a bigger antenna to my microsoft 802.11g Wireless Base Station, it's a MN-700. But there's no where to connect one, or is there? After opening the case I found Broadcom makes the electronics, and found this schematic on the broadcom site.
    Here's whats inside.
    And a closeup of what I hope is my easy way to connect a antenna.
    Can anyone shed some light?
    Can I just plug in?
    Can I solder a antenna in there?
    It's the cake having/eating thing.
    About the only help I can provide is this link to help you determine what connector that is. Also you may be able to check out that site for replacement antennas, signal boosters etc. One thing though I think they may have a $100 minimum order! But you may find what your looking for then search ebay & the like. Also check out this site .
    Hope this helps,
    Dave
    System:
    Epia M1000 w/512MB PC2100, Xenarc 700TS, ATI 7500 PCI, OPUS 150 PSU, 2.5 40GB 5400 HDD, 802.11g PCI, Slim Slot DVDR,
    Gyration RF Kybrd, OBDII adpt. + sftwr, XP pro, iGuidance/Royaltek GPS NAV, XMPCR, Kenwd KAC-8401 4 chnl amp, 10" pwd sub
      Hope this helps,
      Dave
      Thanks for the links, I have looked at a lot of connectors online. There are a few that look like they might work, but I was thinking someone here might know the correct one.
        More Mods...
        I'm not completely sure, but the brass connector looks like an MMCX connector. Take a look at my web site uner WUSB-11 Hacks . I tried to remove the existing antenna and add an external antenna that has an MMCX connector. I messed up the connector/solder joint/RF output. Now I have a dead WUSB-11.
        However, you MAY be able to add an external antenna merely by plugging into the existing MMCX connector on your board. I bought a cheap external antenna from Pacific Wireless . It's a cheapie ($15.00) so it probably won't work all that well. I never got to that point. Give it a try. For $15.00, it's probably worth the lessons learned!
        Good luck,
        MikeH
          Originally posted by MikeH
          More Mods...
          Good luck,
            More Mods...
            Good luck,
            It looks like you did a good job!
            Were did you go wrong?
            I have seen that connector online. Also several others that look almost exactly the same. It's hard to tell how big they are.
            Looks like it could be MC, MCX, MMCX, Reverse MMCX, Alprox, U.FL (found here http://www.jefatech.com/category/cable_assemblies.ufl/).
            So Many to choose from, I don't know were to start.
              I think we should compile a database of the antenna connectors for all of the various WiFi cards that are used, that way we can narrow down converters and antennas more easily, just a thought
                Yep, I am wishing we already had one............
                  I sent an email to jefatech.com with a link to this thread. I asked if it was U.FL and they say that's what it is.
                  I got a very quick reply from them.
