Broken antenna
  • Broken antenna
    So I was trying to change the bracket on my new D-Link DWL-AG530. I say new because this is the second one I've had (the previous one broke as well). This time I had only CAREFULLY pulled back the heat shrink they have attaching the antenna cable to this support post when the antenna came off. The solder points are very small and the connector does not even go through the board. It is just soldered to the surface. My question is:
    How do I get this
    Soldered back onto here
    The places I have to solder are very small and I have no idea how I will resolder the point that is in the middle.
    Thanks for any helpful hints.
    ATVMS.com
    Nobody?
    ATVMS.com
      There are special soldering irons that use heated air to solder stuff like this. If all you have is a normal soldering iron, try this:
      1. Remove as much solder as you can from the connector and the corresponding solder points on the board. Use a desoldering 'sucker' or solder wick.
      2. Apply a small amount of solder onto the centre pin of the connector. You want to create a small solder bump on the pin so that it sticks out slightly from the 4 "supports".
      3. Apply solder onto the corresponding pad on the board - it looks like a through hole so make sure to apply enough solder to fill the hole completely and have some leftover to create a small solder bump above the surface of the board.
      4. Place the connector on the board and align it so that the pins on the connector line up correctly with the pads on the board. The solder bump on the contre pin of the connector should be touching the corresponding solder bump on the pad- this will lift up the connector slightly above the surface of the board.
      5. Heat up the pad on the OPPOSITE side of the board - this will melt the solder through the hole and the solder bump on the centre pin. When this happens, the connector will seat nicely onto the board. Remove the soldering iron and let the solder cool down. After a few seconds, the connector should be held firmly in place by its centre pin.
      6. Check that the the remaining 4 'supports' of the connector are still aligned to the corresponding pads on the board. Solder these supports to the board - don't put too much solder on each contact to avoid forming a solder ball under the connector which could short to the centre pin.
        If you use a butane torch heater, and some of that 'solder tape?'...
        The stuff sticks to the part, and the torch heats it up to flow the connection.
        OR you could simply solder two wires to the board, then the same wires to the connector...then glue the part down after it is all soldered together.
        current projects
          Thanks for the responses. I just got done with it. The solder joints are much stronger than the originals. Still need to test to see if it works now. Fingers crossed. Another question I had was is that a MMCX connector? I want to get different antenna for this card. Appreciate you help.
          ATVMS.com
            Okay, so now I am testing it and I'm not sure if this is a problem with the card or something else in my setup. Windows keeps popping up the balloon saying click here to see available networks. I click it, see my wireless network, select to connect to it, click the connect button, and then nothing. Then the balloon comes back and we start over again. Any ideas?
            ATVMS.com
              First off, yes, that is a MMCX connector. The cable will actually "unplug" from the base connector. As for your next question; did you install the drivers for the board BEFORE installing the board itself? Have you checked your LAN connection settings in network properties? TCPIP etc.?
              System:
              Epia M1000 w/512MB PC2100, Xenarc 700TS, ATI 7500 PCI, OPUS 150 PSU, 2.5 40GB 5400 HDD, 802.11g PCI, Slim Slot DVDR,
              Gyration RF Kybrd, OBDII adpt. + sftwr, XP pro, iGuidance/Royaltek GPS NAV, XMPCR, Kenwd KAC-8401 4 chnl amp, 10" pwd sub
                Checked LAN settings. Right now there is no WEP or anything that should stop the connection. My laptop is connecting just fine to the wireless connection. Is there something else I should check?
                ATVMS.com
                  Okay, so I finally broke down and called D-Link tech support. After half an hour of painfully going over everything I had already tried, they had me go into my router and disable the 4X mode and set the preamble to short. Not sure what this does as I am not very keen on the wireless network stuff yet. I just know enough to get myself into trouble occasionally and then back out. LOL
                  ATVMS.com
                    XP has a lot of built in wireless network stuff to make life better...however that may be your problem.
                    current projects
                      Was and wasn't. I had to turn the 4X mode off and set the preamble to short on my router. Connects flawlessly now. Now I need to get a different external antenna. I want this 7db gain one on ebay (http://cgi6.ebay.com/ws/eBayISAPI.dl...sort=3&rows=50 but they don't have one with an MMCX connector (which I can now unplug and plug in without worrying about that stupid thing coming off the board). Where can I get an adapter to use with one of these? Or would I be better off getting an amplifier and one of the 5.5db antennas.
                      Edit: May try building my own because of this:
                      TITLE 47--TELECOMMUNICATION
                      CHAPTER I--FEDERAL COMMUNICATIONS COMMISSION
                      PART 15--RADIO FREQUENCY DEVICES--Table of Contents
                      Subpart A--General
                      Sec. 15.23 Home-built devices.
                      (a) Equipment authorization is not required for devices that are not
                      marketed, are not constructed from a kit, and are built in quantities of
                      five or less for personal use.
                      (b) It is recognized that the individual builder of home-built
                      equipment may not possess the means to perform the measurements for
                      determining compliance with the regulations. In this case, the builder
                      is expected to employ good engineering practices to meet the specified
                      technical standards to the greatest extent practicable. The provisions
                      of Sec. 15.5 apply to this equipment.
                      http://www.qsl.net/n9zia/wireless/appendixD.html Could make a 5 watt hella amplifier and get signal connected to people across town and it would be legal. I didn't know it was that powerful
                      ATVMS.com
