Any way to use your car's antenna as a WiFi antenna?
  • Any way to use your car's antenna as a WiFi antenna?
    I think it would be a nice integration since those of us who ditched the headunits have a useless antenna. I want to put it to use!
    You read my mind
      Antenna's are made to specific lengths to match the radio frequencies that you are trying to receive or transmit on. FM radio is in the lower half of the MHz band, while WiFi is well into the GHz band. Then there's other stuff to consider like antenna resistance and impedance. If you tried to simply rig up a WiFi device to your car antenna, you would risk toasting it's transmitter. Even if you figured out how to safely hook it up, the antenna would give you very poor reception for the application.
      The only alternative you have is to replace your car antenna with one that is made for WiFi. You can buy them (they are quite short by the way), and you would have to fabricate a way of mounting it as the connectors are totally different.
      Carputer progress meter: [-----|]
      Carputer gadget meter: [--|---]
        even if it does not work it was a great idea, because i never use the radio.
          you could always drill a hole and look like a police car ;x
          Crouching Tiger, Drunken Kitty
            That's a negative, Sir! hehe
            I just thought that attaching the WiFi antenna to any other long piece of metal (even a metal hanger) would increase the reception, so why not attach it to the car's antenna....it doesn't need to be amplified, so how would it toast the transmitter?
            Sorry, i don't understand all this WiFi stuff yet...
              It's all about the adapters!
                The output transmitter section of a WiFi client is "tuned" to match a certain impedence (like a frequency-dependent resistor). It looks like a perfect "match" (ie a 50ohm resistor) only at the proper frequency (around 2GHz). Your car antenna is "matched" (looks like 300 omhs) at 88-108MHz and can't really be tuned to look like 50ohms at 2GHz for your WiFi transmitter. Some WiFi transmitters (output power amplifiers) will fry themselves if they try to power an antenna that's not well "matched". Your car antenna COULD look like zero ohms at 2Ghz....That would toast you WiFi PA....
                MikeH
                  The ol' coat hanger antenna scenario works (sort of) because a car stereo only receives radio waves. But if use it for transmitting/broadcasting, it's a whole new ball of wax. WiFi fits right into that catagory (send/receives). When you transmit, you are actually sending power to the antenna. If the antenna is not properly matched to the transmitter, it will cook itself.
                    I understand now....
                    so, had anyone developed a WiFi antenna that can be lowered and raised with a button? I'd like to try to utilize that antenna of mine or replace it with something else that would work.
                      heres my idea.
                      what about using my cordless phone's antenna? it's longer than the one on my wifi card and same frequency 2.4ghz.
                        Used a pringles can as an external antenna on my dlink in my laptop and used a coffee can @ my friends house and was able to get a link from his router.
                        1 mile away! I have the directions if anyones wants them!
                        www.natchezss.com
                        God Bless America and Our President!
                          1 mile away!
                          That's freakin' amazing...here in NYC, that would essentially ensure a constant signal using netstumbler! however, there is no way in hell that i am going to mount a coffee can to my roof or trunk!! hahaha
                            I've seen that done before on the show the screen savers. They used a coffee can to increase thier wifi signal, it worked really good.
                            The cordless phone antenna would be much better looking in a car, if it works.
                            Installed
                            Asus A7N8X-VM - AMD Mobile Athlon 2400
                            512 Ram - 60GB HD - Opus 150w
                            Lilliput 7" - Rikaline 6010
                            [00000000000001100010-] 98% Completed
                            Check Out My Install!!!
                              Actually, some of the multi-band cellphone antennas have a ~2Ghz band. they also come in car-mountable versions. This might make a much better looking design.
                              MikeH
