Just got USB Orinoco....problem
  • Just got USB Orinoco....problem
    Theres no place to plug in my 7db antenna. It's the gold version if that matter, does anyone know if maybe this is a newer version or an older version? Or are there modifications that i need to do before i can hook an antenna to it?
    Most usb wireless devices I've seen do not have a place for an antenna, unless it's already built on. The only Orinoco device I've seen with an antenna jack are the PCMCIA cards. Lots of PCI cards can take a different antenna, and so can access points, which some you can use in client mode.
    Tidder
    Try RevFE
    I Wish I could ban people
      Oh! This adapter you have is just like the RG-11 gateways I've used. You can crack open the case, and there will be an unbranded orinoco PCMCIA card inside. You can hook up an antenna to that card, but you will have to drill a hole in the case. You may also have to get an antenna jack adapter (pigtail) if you have a non-orinoco antenna. The antenna jack on the PCMCIA card I believe is called an MC Card.
      Tidder
      Try RevFE
        I did open it, and there is no PCMCIA card in there, its just a regular circuit board type of thing. And there is no place to plug anything in except the usb cable
          Do you have a model #? Does it look kinda like a black shark fin?
          Tidder
          Try RevFE
            Here's a pic of it opened
              Oh man, sorry not the one I was thinking of. This is what I thought it was.
              http://www.digit-life.com/articles/l...usb/or-ins.jpg
              Tidder
              Try RevFE
                Do you have any model #'s? You sure that one's orinoco?? One of Orinoco's main selling points is mainstream blah blah with using PCMCIA cards in all of their wireless products.
                Tidder
                Try RevFE
                  model number: 03MT31007307
                  i think
                    Where did you get/purchase it from?
                    Tidder
                    Try RevFE
                      ebay...so i can forget about returning it. Anyone want to buy this off of me for $30 shipped? Thats how much i bought it for....and it was brand new, the box was sealed...not anymore.
                        Sorry man, I don't think it's ornioco. You got taken. $30 ain't bad though. The real orinoco stuff goes for like $65 and higher.
                        Tidder
                        Try RevFE
                          It's got a printed antenna which is very difficult to bypass... I would reccomend not You would need to solder the coax to the base of the printed antenna, then scratch out the copper from the glass. I know how to do this but I would never attempt it unless you don't mind ruining the adapter.
                          2001 CL Type-S
                          2.4Ghz Celeron, Opus, Liliput Jiggered in, but not fully installed
                            it is an orinoco, cause the box is labled Proxim and Orinoco and so is the card itself.
                              Yeah, you're right, it's a proxim with orinoco tech. in it. All the Orinoco Gold USB devices I was looking at was Lucent/Agere. They go the extra mile with the PCMCIA cards still. Proxim cheaps out and just integrates. Probably becuase they own orinoco.
                              Tidder
                              Try RevFE
