Anyone using an 802.11B amp & high gain antenna combo?
  • Anyone using an 802.11B amp & high gain antenna combo?
    I'm working on putting a computer together for my RV. I plan on putting a high dBi antenna and possibly an amp. Has anyone else done this? I'm talking 12-15 dBi and 500mW to 1W amp combined with an Orinoco Gold card.
    The only problem I forsee is that high dBi omni antennas have a low vertical beam width (8 degrees, such as http://www.hyperlinktech.com/web/hg2415u_pro.php). That means that if I have it raised well above the roof of the RV (which is almost 8 feet) it will be 11+ feet up. If I understand it correctly, I won't get a very good signal with closer APs correct?
    It will be used mostly for picking up distant weak signals so that really shouldn't be much of a problem right? If I do the math out correctly the beam should be at ground level after only a few hundred feet. I want to be picking up signals from at least a mile away. Running 1W on a 15 dBi antenna I should be able to get much farther than that.
    89 Mustang (Autox, road race, and cruiser)
    93 Escort (Daily Driver)
    84 Dolphin RV (Soon to be Carputer Heaven)
    You should have a "reality range" of around 1/2 mile or more. I have the 8db antenna from hyperlink with 500mw amp with netgear pci wifi card. I have range about 1/8 mile.
    heres a pic
    www.john1701.com/mp3meet2_020.jpg
    CAR:2001 Ford Crown Victoria
    PC: Acer EEE 900HA with Win7 with CF 2.0.
    Memory:1G
    Drives:160gig
    WI-FI:Cingular
    GPS:IG2k9
    Screen:Xenarc 700TSV
    The Florida Meets Thread
      That's the antenna I have now. I was disappointed by the lack of range with it. A 12 dBi antenna will be ~3x better than an 8 dBi. Combine that with the 1W amp (with receiving gains of ~17dBi) and I'm hoping to get signals from much father away. We will see...
        I have a good range with mine, but I would like to have 1w amp.
        Memory:1G
        Drives:160gig
        WI-FI:Cingular
        GPS:IG2k9
          I have ordered everything so I will post how it turns out. 40.5" 15 dBi antenna with a 1W amp using an Orinoco Gold card.
            Since I am in the wi fi hotspot market I gotta say that remember the AP has a role to play in this as well, you may have all the power in the world on your end but if the AP is poorly setup or has poorly placed antenna then no matter what you have, your connection will be lousy
            Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
              damn that stuff iss expensive 700 for the amp^^
              Golf 3 CarPc Status
              ///////////////50%--------------/
              PSU:Inverter
              GPS:BT GPS
              PC: Slim notebook with 10.4"touch, external DVD.
              Dock for car is in production.
              Audio: Stock speakers but looking for new ones. CD-HU with FM modulator (ordered)
                if ya wardrivin, you can look for a stronger AP. Plus with 1w amp, he should find quite a few more AP's than I can with a 1/2 w amp.
                Memory:1G
                Drives:160gig
                WI-FI:Cingular
                GPS:IG2k9
                  Uh no. Try $260 (http://www.fab-corp.com). First one on the amp page.
                    What power supply do you plan to use for that thing? Looks like it's 9v...seems to me like for a radio amplifier a clean power source would be essential
                      Probably a 12v to 9v from Radioshack but we'll see how that works after testing.
                        I take it your using a omni antenna? If your useing a directional (bi quad for example) with 1w you would be well over a mile.
                          Ok, I'm going to reiterate what SAScooby said as it seems to have been ignored. Consider the following:
                          Two people are stood at opposit ends of a football field. One is talking very quietly, whilst the other is shouting. How effective is the two way communication going to be? Whilst the person shouting can give instructions to the other person, the person swisperring is not going to be able to get commands or responses back to the other end.
                          Now consider this in your Wireless Network. Your WiFi card, amp, Antenna could be so great that it could shout for miles, but if the Acess Point (AP) is only wisperring then basically your screwed.
                          Now, obviously if you own the Access Point and are able to make that thing shout too, then it's a whole different ball game.
                          06 Volvo XC90
                          Use to have installed MII 10000/512Mb/40GB, Lilliput 7", OPUS 90W, Wifi-G PCMCIA, Head Unit Aux adapter, Delorme GPS, XM PCR, Audigy NX, RR
                          Car PC downloads: http://carpc.harteveldt.com/
                            I am very aware of this. The true reason for getting an amp was the following: Receive Gain 17 dB typical An extra 17 dB gain is crazy.
                              so that's how people get crazy range with their cantennas and such-amplifiers.Interesting...And I thought there was something terribly wrong with mine.
