Wireless Help with Dialup Internet
  • Wireless Help with Dialup Internet
    Ok i've got a problem
    I've got a wireless router and a wifi card for the carpc
    But cause my car pc hasn't been finished my sisters been using it for wireless internet.
    I've got dial up so i'm using ICS to share the internet but i can't do ICS and FILE SHARING by itself so i have to switch it from file sharing to wireless internet but the problem is it takes so long to switch from one to the other.
    How can i share my files on the car and also share the dialup internet for the laptop at the same time?
    I really need help
    I'm not using a crossover cable but would that help at all?
    When i share files i can't click ICS as it says the ip address is conflicting or something along thoese lines.
    I really need both working i know the wireless router wasnt made for this so please help.
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
    If you're willing to use a wired connection between the 2 computers, you could either use a crossover cable, or you could get a USB File Transfer cable. I used a 50ft. crossover cable for years to share Internet/Files between 2 computers when I was to broke to buy a router/switch.
    1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
      That doesn't help me as the Laptop is on the other side of the house far far away.
      There must be some way to share the dialup internet and the files at the same time.
      Please someone must know????
      CarPC Status:
      GPS: 99%
      Hardware: 99%
      Software: 92%
      Case Install: 99.9%
      Dash Install: 100%
      Car Install: 72%
