WLAN better signal with PCI card or USB dongle
  • WLAN better signal with PCI card or USB dongle
    Hy!
    I am deciding between WLAN card (mounted in PCI slot in computer in the trunk) or USB dongle on 3m cable and mounted somewhere on the top of the car (roof). What do you think it would have better signal?
    PCI card:
    USB dongle:
    Thank you very much for you answer!
    Regards!
    Uros
    System: VIA EPIA EN15000,512 MB DDRII,M2-ATX,300GB HDD,XENARC 1020TSV,VoomPC case
    USB: Powermate,WinTV+FM,WLAN 54G,Bluetooth,Haicom GPS mouse SIRFIII
    Software: Windows TinyXP Rev06+MinLogon+EWF+HORM+Centrafuse 1.2
    Honda delSol project
    CarDomain
    I would steer clear of both of those types of wireless cards. I have had HORRIBLE experiences with the pci type, mainly because half of the signal has to travel through a metal case, which is almost certain to kill the signal almost completely on that side.
    In my house I couldn't even have a computer across the hall from the router with one of those cards. I'm guessing usb dongles are similar.
    It's not a big problem with internal laptop wireless cards because they have less metal to go through.
    I would ditch both of those in favor of a good usb wirless module (the ones with a little antennta and a long cord)... you could mount it anywhere you need, just make it away from the computer.
    Hope that helps.
      what about a pci card with a 7dbi antenna on the roof of the car?
      i got dat ***** sittin on 22s! SUPERMAN EDITION!
        Ok, thanks for quick answer. I already have PCI card tested in the trunk. I live in 3rd floor and I also have an access point there, I parked the car on a parking place (about 30 meters air-distance) and signal was low. So I wonder if it will be better with USB dongle.
        Do you mean, that exist an usb dongle with antenna like antenna on PCI card on the picture? Can you give me some url to look for it?
        EsKALad: How 7dbi antenna looks like? Where is it possible to buy it?
        CarDomain
          i saw a few on ebay..they are magnetic and cost like 10 to 20 bucks...im thinking about doing that with a pci and external antenna OR sliding in a pci to pcmcia adapter and use tmobiles lan card...i dunno yet..opinions?
