Please Help...
  • Please Help...
    please remember i know to this. thanx for reading my post. help. i have a pioneer avh-p6400 and i would like to know what wires/hardware do i need to buy for me to be able to connect my monitor to my pc since there is no RGB input. here is a image of my monitor.. PLEASE HELP. hope i make sense in what i am saying..
    http://www.dealtree.net/img.asp?i=DT_16294_2.jpg
    http://www.dealtree.net/img.asp?i=LOT_231870_1.JPG
    http://www.dealtree.net/img.asp?i=DT_16294_1.JPG
    Casetronic C137 Mini ITX Aluminum Case w/90W PS
    VIA EPIA-M10000 Motherboard w/ VIA C3 1GHz CPU, Video, Dolby 5.1, 6 Channel Audio, TV-OUT(S-Video), USB 2.0, IEEE 1394, LAN
    512MB DDR RAM
    Seagate 160GB ATA100 Hard Disk
    DVD-ROM Slim Drive
    (2) 1600 watts legacy AMP
    (2) PIONEER TS-W3004SPL 3000W PREMIER 12
    Creative Labs Audigy 2 NX External Sound Card
    AC-DC 400/800 watts
    How is this related to wireless communications?
    Epox EP-3VWB+ w/VIA C3 750MHz
    Crystalfontz 632 16x2 LCD
    DWW-7VGA 7" Indash VGA w/Touchscreen
    Garmin GPS 18 USB
    Terk XMD1000 XM Tuner (My VB6 Class)
    Scantool.net ElmScan ISO (My VB6 Class)
    PSK-3100 Traveller Keyboard
      first thing you've posted your question in the wrong forum. Anyway, to answer your question, that screen takes composite input only. To convert it to VGA would be way more trouble than it's worth. If you really want to use it, you will have to have a video card in your computer that can output to composite (TV-out), if you do this however, the quality will be quite poor and you probably won't be able to read text on that small screen. I would suggest you buy a VGA screen for use with your carputer.
        What everybody else said. If you can return the Pioneer, I'd do it. The Pioneer only takes composite video inputs. That is different from the VGA output that computer monitors use. That is a digital signal.
        However, I see that you list an Epia as your computer. If you are unable to return the Pioneer or do not wish to purchase a VGA screen, you can use the S-Video output on your Epia. Get an S-Video to RCA adaptor (very cheap) and use an RCA cable to connect it to your Pioneer. To preview the difference, hook up your computer to a TV and you'll see the difference.
        You may have to adjust the settings in your BIOS to get the video output to work.
        Want to:
          Can/t remember if yours has a nav input but, Input threw the pioneer nav input. It's a cga input, you can get a scan converter on the net to take vga to cga. Also search google for the pinout of the pioneer nav.
          Done it with pioneer and the alpines. Looks pretty good buy not like a normal vga monitor....
          Bmo
            well since you say the visibility won't be as good as a vga i will just go and buy a vga screen like you say.. thanx for the info bug and BMO.... whenever i am finish with this setup i will put some pic and sorry for posting in the wrongf fourm...
            peego
