stream music from 14.4k
  • stream music from 14.4k
    i'm tryin to stream music from a 14.4 connection. bascially the comp is connected to my verizon cell phone by usb. and the speed is really slow (14.4) so I want to know if its possible to stream music from like live365.com or something.
    use winamp shoutcast i used to host a online radio show off of that its got some good settings where u can tweek it on the quality and allow a certin ammount of users to connect try www.winamp.com www.shoutcast.com have fun
      Dude, give it up, 14.4 will sound like a fork rubbing against a tin can.
      [H]4 Life
      I'm a lesbian too.
      I am for hire!
        he is right
        BenjaminS
        Powered by Imagination
        http://www.ccarproject.net/
          agreed. the lowest quality stream you can find out there is around 24k-ish. this would require AT LEAST a 33k connection. recommended is of course 56k if not higher (like what you would find on EVDO networks)
          Your everyday carpc geek and tech guru at your service. *bow*
            well... unless a fork rubbing against a tin can is right up your alley
            •Micke
              What kind of Cell Phone is it? There might be a setting on it that you can use to connect to the Express Network (1XRTT) ~150-235KBPS!
              Peace,
              Rafster
              Post # 3000
