$5 DYI antenna?
  • $5 DYI antenna?
    Have you tried building this one? Looks very sweet and very low-profile for omni antenna. I think I might build one
    This appears to be the right socket for building "spider" antenna, $3.29 + tax.
    Asus K8S-MX ~ Athlon 64 2800+ ~ Kingmax MPXD42D-2K 1Gb ~ Seagate ST960822A 60Gb ~ PSK-3100 PS/2 kbd ~ MR-350 GPS ~ Hawking HSB1AP ~ Buffalo WLI-USB-G54 ~ 8" Dynamix TS LCD ~ DSATX ~ XCard ~ TVedia ~ some LCD TV ~ Vista ~ MapPoint 2006 ~ iGuidance 2.*
    Yes, I have, but not for 2.4 GHz. However, you are not going to be able to find that in ANY Radio Shack. If you do, count yourself extremely lucky. They are used for building pretty much any antenna out there, mostly for Hammers. I don't think we even carry it anymore in the stores. You may have to order it online (better get it from mouser)
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
      fab-corp.com sells the N connectors, I built a pringles can yagi once, worked really well
      PC Components:
      My work log
        but only a 3 db gain. i guess thats better than nothing but i would prefer a larger gain
          Is that one I found the right part? If so, I just got one from local Radio Shack, they had two in stock. I think I'll try making this antenna just for kicks - even if it is 3dbi gain, it is still low cost and low profile
            Do you know what it's spatial profile? From the looks of it, it should be pretty wide in all directions. As for 3dbi gain, I'd rely more on Hawking's amp than on good antenna
              You don't want to use an SO-238 connector on 2.4 GHz, they are too lossy at that frequency. You need to use an N-connector or BNC instead.
              Z
              Zotac N630I-D-E M/B w/ Nvidia 7100, E5300 cpu, Xenarc 700IDT, M2-ATX, XP, RR & DFX 5.1.
                Like "N Female Panel Mount" here? Damn it, good thing I haven't opened mine
                Can you folks tell which cable should be used between "reverse plug SNA antenna connector" and this connector? This one?
                  Are you talking about between that cable and a reverse SMA connector on your card? Or between the antenna and the card?
                  Either way, use anything from LMR-195 or smaller. The 195 is pretty rigid, so I wouldn't try connecting it right to your card, unless its not going to be moved often. (I tried, ended up fixing the connector.) The smaller cable is more flexible, but more lossy.
                  2000 Subaru OBS
                  Dell P3 @ 900 Mhz
                  80GB External HD
                    Between the N-type connector (i.e. "spider" antenna) and the plug in Hawking HSB1 amp; they tell it's RPSMA.
                    What radius can you bend LMR-195 with? Edit: 1/2" sounds quite flexible.
                      No, you can bend it. Its just stiff. But between an amplifier and an antenna that are both permanently mounted somewhere, go as big as you can afford. Again, the bigger you go, the less flexible, but also less loss.
                      Here's a calculator I use:
                      http://www.timesmicrowave.com/cgi-bin/calculate.pl
                      2000 Subaru OBS
                      Dell P3 @ 900 Mhz
                      80GB External HD
                        by reverse are you sure its not reverse polarity sma?......make sure you have your polaritys right or the antenna wont do you any good
                        PC Components:
                        My work log
                          Very cool calculator!
                            Here is the product. I cannot tell better, can you?
                              I'd buy one if someone decides to start the making lol
