verizon highspeed ok continue window
  • verizon highspeed ok continue window
    i'm using verizon's highspeed card. i use windows connect to connect, not the verizon software.
    when i go 'start/connect to/verizon'
    it gives me a little status/pre-dial monitoring window that says 'ok' in it, and i have to click 'continue' to connect.
    i don't understand why - is there a way to disable this? i went under properties and unchecked everything having to do with status windows.
    i don't know what i'm missing, i went over it a dozen times. anyone know how to get rid of this stupid status window?
    Maybe you can write your own apps to do the click for you.
    You can try to do a little search for Routis/Iguidance and warning on how people come up with app to auto click OK on the warning window. The same idea, different apps.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
      howardforums.com
      Take my advice: Do not try to build a system that includes EVERY feature. Start with the basics, build it to a bug free state, and THEN add on.
