Your PCI 802.11 experiences?
  • Your PCI 802.11 experiences?
    Ok, so there are USB and PCMCIA 200mw solutions availiable for around 100 bucks, but let's not worry about those for now.
    Name some of the cheaper 2.4 ghz 802.11 PCI or USB have you tried and acheived good results with.
    If you've had lots of experience with some of the lower priced PCI/USB solutions which of them would you reccomend?
    I'm using a FoxConn WLL 3350 and am fairly impressed with it, but haven't had enough experience with other solutions to make a fair comparison.
    I have a Hawkins 802.11G card with an external antenna (mounted next to the PC) and I have had no problems with it. It works fine in my garage, with 3 walls in between. I only paid about $30 from Newegg.
      I have a FoxConn too and it works great in the driveway which is 100 yards from the router with numerous walls in between. I have an ant. on the roof and don't think I could do much better.
        100 yards from YOUR router? That's a HUGE house. What antenna?
          Just a cheap one from ebay. It came with one but the cable wasn't long enough. I'll try and find a link when I get a chance. It's PCI by the way.
            Where in Alabama do you live? You sure it's 100 yards?
              The house ain't that big. It's a long rectangle. it's at least 80 yards. I can also see my neighbor's router one house down and across the street but I barely get a connection to his.
                I have a PCMCIA card and between here and the shop we use to get papers (about 1.5m) it picks up about 8-12 APs. but will not pick my own router up with the car sitting on the drive next to and below the room its in. But will pick it up on the other side of the house about 10 yards away. Not a problem if I cant pick it up there's a chance no-one else can either as its about 60 yards to the road from the house. The card didnt cost me that much about 20.00 (Ebay noname card) I have a Maplins antenna its cable will just about reach the windowcill never mind the roof (9" lead) and its pointing towards the other side of the house. Hence the pick up differance.
                http://www.maplin.co.uk/Module.aspx?...tenna&doy=23m1
                EPIA MII: 512m Ram: LinITX 8" Touch Screen: Carnetix P1290 PSU: 802b PCMCIA Wireless card: Slot DVD Player: Touchpad: Wireless Keyboard: BU303 GPS Mouse:
                Win 2000: RoadRunner Front End: Michelin Mapstore GPS: Netstumbler:
                  your house is as big as a football field?
                    saffs
                    I was wondering the same thing.. I think he meant from the end of his driveway to the AP in the house. I've personally never seen a 100 yard house corner to corner, but then again, i live in AL
                    But then again, so does he.
                      I bought the excellent Gigabyte PCI card from Newegg. Only $20 now! It is also the SMALLEST PCI wifi card I have seen... check it out, the PCB is very small!
                      2002 Honda CR-V
                      Spent so far: $1105.90
                      ...or even Listen to my music
                        On Black Friday, I made 2 stops: CompUSA and WalMart. WalMart had HP ZE2000 notebooks for $378 and CompUSA had 200G HDs for $29 (of course I got 3 of each), but while I was at CompUSA I saw they had CompUSA branded USB 802.11G dongles for 3.99 after rebate. I figured what the hell and picked up two.
                        Man I wish I'd have grabbed a dozen or more! These little Dongles work great on both USB 1.1 and 2.0. No external antenna, but I get acceptable range from them (100 mW power output).
                        They do have one downside and that is I found they work best at the end of a 6 foot USB extension and mounted as high as possible (I'm considering weatherizing one and mounting it in my rear spoiler.) The extension helps dissipate the heat they generate. Had one directly connected to a tablet and after 2 hours it became erratic, I later figured out it was getting overheated.
                          I use a realtek rtl8180 pci card connected to a 15dbi antenna for my home internet. The AP is about 300-400 feet from my home with a mildly obscured line of sight. I have used it for years, at $25.00 a month, with an average of about 300kbps down speed. I know thats weak but I live in the sticks of indiana and all my buddies have 56k, so I'm doin ok in my circle- I am generally always connected at 5.5mbps rather than 11mbps, sux.
                          current system: car2pc adapter playing aux in for a sansa fuze media player. simple. cheap. effective.
