Help me please! Bluetooth connection failed!
  • Help me please! Bluetooth connection failed!
    Hi I bought a usb bluetooth dongle to sync my phone with outlook on my pc and to transfer files. It only works SOMETIMES, however. Most of the time it can not connect to the serial port service. It pairs with my phone fine. Then I choose my phone in bluesoleil and click the serial port button. Sometimes it says connected and works a for a short time, most of the time it just says "starting connection" for a while, then "connection failed". My phone is a Siemens Sp65.
    I also have problems with bluesoleil / blue soleil..
    Black SolarCell Portable Bluetooth Gps reciever for sale, Contact me!
    BMW E46 320 Touring project thread, making the perfect multimedia car ;)
    BMW E46 WORKLOG
      Funny. I have ZERO problems with BlueSoleil drivers. Most people have issues with Widcomm crap.
      How about the Wiki?
        widcomm 5 works perfectly for me, couldn't get isht going with the bluesoleil stuff..
        Dr. Ron Paul for President 2008
        Hope for America - http://www.ronpaul2008.com
        Who is Ron Paul? - Why do we need Ron Paul?
        CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
          Bluetooth got you blue?
          I have fought with BT on my boxes for years here are some tricks:
          XP SP2 is a must!
          With that said do NOT use Microsoft's BT drivers. The idea here is force the use of YOUR devices drivers. Even if you use your devices setup program, somehow someway sometimes MS will install its drivers. In addition, I have noticed that sometimes both MS and your devices will seem to be active at the same time. You need to disable the Mickysoft drivers... Notice that I said DISABLE. Do not uninstall the drivers - they will only come back. Microsoft Bluetooth places ICON is generally larger than linksys and others that I have used.
          Some specific installs that I recall require multiple drivers off the CD be manually loaded. After loading a linksys dongle and forcing the use of it's driver opposed to the stock MS driver - you need also to update the drivers (! Yellow mark in device manager) Bluetooth Com Port from the CD that came with the linksys dongle.
          Hope this helps..
            For me a hibernate make some devices work partly or not. Fore example, my bluetooth dongle is always blinking after insert into usb port. When back from a hibernate it often goes to just permanent light. Someone with a fix?
            BMW E46 WORKLOG
