unable to connect with my phone
  • unable to connect with my phone
    I just spend last 5 hrs trying to fig out the phone control.
    I am still under construction so I am trying this on my laptop and desktop. Phone control finds my Razr V3 but no contacts are pulled to the program, unable to dial, recieve or SMS
    I even bought another Bluetooth adapter but no luck.
    I also tried with usb cable that I use to sync with my Razr for Motorola Phone tools.
    Any sugestions?
    Greg
    Chicago
    Is there anyone that got the phone connect to work?
    I've been working on this for few days and I am pretty good wit PCs and all the tech stuff.
    I got to the part that I can get my pc to act as a handsfree device thru bluetooth but within the Centrafuse software the most I ever got was that it was displaying one (1) sms message.
    No contacts or talking thru the PC.
    HELP
    HELP
    HELP
    HELP
    HELP
    HELP
    HELP
    HELP
    HELP
    HELP
    HELP
    HELP
    HELP
    HELP
    HELP
    HELP
    HELP
    Greg
      I did extensive debugging on this and I figured out how to get the Razr V3c to work with phoneco. The problem is your USB drivers.
      I used hyperterminal in windows to send modem AT commands to the motorola phone and I discovered that what happens is the AT command to retrieve the phone directory from your phone times out.
      To fix this, you'll want to go into "my computer/hardware/device manager" and remove your current USB driver. Then plug your phone in using a USB cable. When it auto-detects, force it to use the USB drivers I've attached to this post.
      In phoneco, select E815 as the model of phone that you are using.
      8" Lilli TS
      MB896F Mini-ITX MB
      2GHZ Dothan 533MHz FSB CPU
      1GB SDRAM DDR2 533
      Seagate 300GB SATA150 HD
      ENGENIUS WiFi MINI-PCI CARD 802.11A B 400MW OUT
      Pioneer Slot Load SLIM DVDRW
      Bluetooth V2 USB 2 Dongle
      3COM BKP Cam
        Will the driver you posted work for the e815?? I am having problems connecting my 815 by usb...
          I don't know. I don't have an E815. The driver is, I believe, for all motorola phones though so you could give it a try.
          8" Lilli TS
          MB896F Mini-ITX MB
          1GB SDRAM DDR2 533
          3COM BKP Cam
            ok but what if I'm using bluetooth????
              any updates did anyone ever get this to work?
